Temp needle acting funny on my stock 90 crx dx (help needed)
Old Oct 27, 2006 | 06:03 AM
JokerX-1.6T's Avatar
Default Temp needle acting funny on my stock 90 crx dx (help needed)
Ok so my temp guage sarted acting funny yesterday on my 90crx dx totally stock. After driving like 50 miles my temp guage was on cold and would very slowly rise back up to below halfway (never has been at halfway) at stops then go back down upon acceleration and yes it was semi cold out yesterday morning here in Va, so I was like ok let me check my thermostat and low and behold yes it was in a stuck open position so I replaced the thermostat and now yes it seems to not quite drop all the way but still just doesnt sit at any 1 spot and stay there. so my question is what could the options be to solve the issue and or does it have to do with the full size radiator and just being a little cold out as it was only like 40 degrees this morning? could it be air trapped in the system? or what else could it be this car is new I got it in the summer so never really noticed any issues until the colder weather started the heat in the car is great now that replaced the thermostat.
Thanx any help or ideas would be greatly appreciated
Modified by JokerX-1.6T at 4:33 PM 10/27/2006
Old Oct 27, 2006 | 06:24 AM
89 civic si's Avatar
Default Re: Temp needle acting funny on my stock 90 crx dx (JokerX-1.6T)
bleed the air out of the system...thats most likely your problem
Old Oct 27, 2006 | 06:26 AM
65stang90crx's Avatar
Default Re: Temp needle acting funny on my stock 90 crx dx (89 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">bleed the air out of the system...thats most likely your problem</TD></TR></TABLE> I second that. Thats what it sounds like. There is a 10mm bleeder at the block. Crack open and squeeze the top hose until only antifreeze comes out. Real easy.
Old Oct 27, 2006 | 07:04 AM
yea I cracked open the bleed screw yesterday after I ended up adding water to it to top it off I guess I will just drain out the old and just redo the whole system and see what happens
Old Oct 27, 2006 | 07:10 AM
newman271's Avatar
i had the same issue last week.. i checked the thermo and it was stuck opened so i replaced it bled the lines and everything and while i was at it i went ahead and flushed the heater core. Afterwards still was doing the samething... come to find out my alternator was going out.. i replaced it two days ago and now it works perfectly..
Old Oct 27, 2006 | 08:31 AM
seems wierd that a alternator prob would cause this issue though
Old Oct 27, 2006 | 08:39 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (JokerX-1.6T)
Could be that your temp. sending gauge is malfunctioning as well, I had the exact same problem and that was the culprit.
Old Oct 27, 2006 | 12:05 PM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerX-1.6T &raquo;</TD></TR><TR><TD CLASS="quote">Ok so my temp guage sarted acting funny yesterday on my 90crx dx totally stock after driving like 50 miles my temp guage was on cold and would very slowly rise back up to below halfway (never has been at halfway) at stops then go back down upon acceleration and yes it was semi cold out yesterday morning here in Va so I was like ok let me check my thermostat and low and behold yes it was in a stuck open position so I replaced the thermostat and now yes it seems to not quite drop all the way but still just doesnt sit at any 1 spot and stay there so my question is what could the options be to solve the issue and or does it have to do with the full size radiator and just being a little cold out as it was only like 40 degrees this morning could it be air trapped in the system or what else could it be this car is new I got it in the summer so never really noticed any issues until the colder weather started the heat in the car is great now that replaced the thermostat
- </TD></TR></TABLE>
That has got to be the loooooooooooooooooooongest sentence on HT ever!
Old Oct 27, 2006 | 12:08 PM
Tippyman's Avatar
Default Re: Temp needle acting funny on my stock 90 crx dx (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">
That has got to be the loooooooooooooooooooongest sentence on HT ever!</TD></TR></TABLE>
You should go to kills...
Old Oct 27, 2006 | 12:35 PM
I added a few .'s and ,'s be happy -
Damn It did run on didnt it
Old Oct 28, 2006 | 12:19 PM
90JPRCRX's Avatar
Smells like Tuna
HAHA crazy, mine was acting up tuesday, cept mine is normal at just below halfway, it would rise up to peak and then slowly come back down.
Old Oct 29, 2006 | 02:42 PM
well I replaced the temp sender yesterday and gave it a day of driving and seems the sender was screwed up I picked up a new one and its solid right below halfway now so its good to go again
Old Nov 3, 2006 | 05:55 AM
junior40er's Avatar
Default Re: Temp needle acting funny on my stock 90 crx dx (90JPRCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90JPRCRX &raquo;</TD></TR><TR><TD CLASS="quote">HAHA crazy, mine was acting up tuesday, cept mine is normal at just below halfway, it would rise up to peak and then slowly come back down.</TD></TR></TABLE>
im having the EXACT same prob. How'd you fix it??
Old Nov 3, 2006 | 06:14 AM
Default Re: Temp needle acting funny on my stock 90 crx dx (junior40er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerX-1.6T &raquo;</TD></TR><TR><TD CLASS="quote">well I replaced the temp sender yesterday and gave it a day of driving and seems the sender was screwed up I picked up a new one and its solid right below halfway now so its good to go again
Kanjo EF
Apr 22, 2015 01:24 PM
bcardinal
Jun 5, 2008 07:29 PM
crxricer66
Feb 16, 2008 09:16 AM
DRAGWORKS
Feb 9, 2006 07:19 PM
90jdmcrxdude
Jan 30, 2006 12:02 PM
