Is the HF clutch the same as the SI
Yes/No i know they are interchangeable but form the factory are they the same i need a new clutch and i am getting 2 different prices hf clutch 170 si clutch 200.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Hmm i thought 89-91 dx, si, std, hf clutches were all the same. the only ones i thought were differnt are the 88 models. Bump for a answer</TD></TR></TABLE>
thats what i thought but when am i getting charged more for one ?
bump
bump
I believe that the clutches are the same but there is one difference. The model of the vehicles, your paying because you have an SI either way. Its all in the name of the model of the car. If its an SI part I garauntee that it will be more expensive then the DX or STD part even if they are the same thing. It happens all the time.
TJ
TJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Burgandykilla »</TD></TR><TR><TD CLASS="quote">I believe that the clutches are the same but there is one difference. The model of the vehicles, your paying because you have an SI either way. Its all in the name of the model of the car. If its an SI part I garauntee that it will be more expensive then the DX or STD part even if they are the same thing. It happens all the time.
TJ</TD></TR></TABLE>
<FONT COLOR="green">No it doesn't. You are full of lies</FONT>
1991 HF
83433 001 COVER, CLUTCH CASE NO COLOR 20.57 15.43 Qty: Buy
83439 003 FLYWHEEL NO COLOR 286.27 214.70 Qty: Buy
83440 003 FLYWHEEL NO COLOR 286.27 214.70 Qty: Buy
83450 004 DISK, FRICTION NO COLOR 92.95 69.71 Qty: Buy
83454 005 DISK, PRESSURE NO COLOR 125.63 94.22 Qty: Buy
18546 008 BOLT (12MM) NO COLOR 4.10 3.08 Qty: Buy
11399 010 BOLT, TWELVE POINT (8MM) NO COLOR 4.67 3.50 Qty: Buy
3572 012 BEARING, CLUTCH PILOT (TOYO) NO COLOR 18.20 13.65 Qty: Buy
11400 017 ROLLER (6X17.8) NO COLOR 0.37 0.28 Qty: Buy
1991 SI
83441 003 FLYWHEEL NO COLOR 286.27 214.70 Qty: Buy
83455 005 DISK, PRESSURE NO COLOR 125.63 94.22 Qty: Buy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">I've heard the HF flywheel is a lighter version of the Si. True?</TD></TR></TABLE>OEM HF flywheel weighs 15 lbs - all others weigh 18 lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">i thought 90-91 were all the same and 89 88 were both different.</TD></TR></TABLE>
i thouhgt 90-91 was 212 mm flywheel
89 was 200
and 88 was 190 with a different # of splines on the tranny shaft
89 was 200
FWIW
cx/vx flywheel is 15 lbs
others are 18 lbs
but that's for 5g/6g
88 trans uses the 84-87 style clutch (hence the different spline count on input shaft
89 trans uses same splines as 89-00, but smaller clutch diameter
90 trans = first year of the 90-00 standard
got an 88 trans that you need to put on a 90 engine/flywheel?
I believe you use a 89 prelude clutch
others are 18 lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx »</TD></TR><TR><TD CLASS="quote">so instead of just getting a new clutch for my 88 crx get one for a 85-87 prelude si or 86-89 accord</TD></TR></TABLE>
if your using a 90+ flywheel
Guest
Posts: n/a
Well, my old clutch i took out today is TOAST, whats funny is i already had a extra flywheel, it IS bigger then my old clutch and flywheel of course.
I took my new clutch, lined it up with my old one, the new clutch is taller, and has a more wider area outwards for more contact surface, im excited because it fits on my transmission fine and im suppose to go get my flywheel, "the 90/91" i got, tommorow at a shop, hopefully see if they can lighten it a few pounds possible.
Maireeka
Nov 9, 2008 04:27 PM
white90crxhf
Jan 6, 2006 09:10 AM
The DX Rex
Nov 22, 2005 03:57 PM
