Starting Help
I am having starting issues and trying to see if I can get some help.
I have a 99 Civic Si and once every so often my car just won't start. Like Once a month I'd try to crank it and it clicks but don't start. I'd wait like a minute or two it would then start after repeated attempts. Anyone know what the prob could be. Thanks in advance
Is it the original battery? If so, take your battery to your favorite auto parts store and have them do a test on it.
I've learned that most of the time when you just get a click it's a weak battery or dirty connections.
Make sure your terminals are clean as well as the cables on the battery. One more spot would be the connecton at the starter.
Disconnect them all & wire brush them and then see if the problem goes away.
