OBD2 Port Located?? HELP!
Where is the OBD2 Port Reader Located in 06 Civic... i took the carpet out on passenger side and kick panel and side panel, and the drivers too, and the under dash of driver and i cant find it.....
under the steering wheel to the right...up in the corner just below the dash area...
if u make a square with ur lil driving area....top of the square will be the area under the steering wheel , bottom being the carpet below the steering wheel...the side being the door and the dash area that hold the stero etc...
the obd port will be in the top right corner of the square...
i have no clue if u understand what i'm saying here... but it is in ur driver are under the steering wheel area to the right in a lil corner.
No problems in install i had 3 people look it over.. no leaks all seald, even changed the rubber hose and all... dunno why Code: run too lean... ohh well i guess ill have to get vafc-2 now.....
i dont think where i bought this will take it back so i can get injen or fujita... so might as well move forward and ger vafc2..
problem solve... i had been using 91oct gas.. i dunno why i thought i had to use 87oct... just now i filled it up with 87oct, the CEL went away..... LOL "CODE P0171: Too Lean" NOW GONE YAY!!!!
Xjeffgarrett93
Oct 14, 2012 03:19 AM
preludepower
Oct 12, 2005 10:50 PM
StraightCivic
Mar 6, 2005 07:32 PM
