is it possible to have this tranny...?
Old Oct 26, 2006 | 07:26 PM
AuLit's Avatar
Default is it possible to have this tranny...?
I got a 2k accord EX V6 4AT and i would want to convert it to 5AT, because the stock tranny is... hum.. like a hot sausage... it's not tough at all...
So i asked on other forums, and ive been told that b w/ b, d w/ d, f w/ f ..... what about J with J?
My engine is a J30A1 and i would like to have the automatic transmission (5spd instead of 4) of a J30A5 (2007 Accord's)
Will it fit, bolt-on? Because the two ones are J's, but someone said that it won't work.. Did someone do it?
Old Oct 26, 2006 | 07:46 PM
Legendaryyaj's Avatar
Default Re: is it possible to have this tranny...? (AuLit)
It will fit butmaking it work may be the hard part. The 6spd swaps have been done before but not really with the 5at mainly because its a auto. There was one guy on here who did the swap with a CL tranny but he also used the Cl engine.
You'll need the computer to make it all work. If you do get the ecu you'll need to convince the dealer to make a key for you to match the ECU so it'll all run and start.
THese new car nowadays are so complicated!
EDIT* I could be totally all wrong.
Old Oct 26, 2006 | 08:46 PM
AuLit's Avatar
lol i knew that.. about the computer (who will shift etc..) and the shifter... but the question is... will it fit? i mean.. bolt-on?
Because the two engines are J30A*, so I guess it's the same base etc...
PS: Excuse my english, and correct me if i'm wrong on something, because i'm french ^^
Old Oct 26, 2006 | 08:59 PM
Default Re: (AuLit)
To my knowledge, Yes it will fit.
Will it work though? I have no idea.
Old Oct 27, 2006 | 04:28 PM
YeuEmMaiMai's Avatar
5at trans will NOT fit..... and it will NOT work in any car with a 4spd auto unless you swap the ENTIRE DRIVE LINE AND ECU/TCU. You will not get a 5at to work with the j30a....
Old Oct 27, 2006 | 10:00 PM
AuLit's Avatar
I know i have to change the computer and ECU, but once this will be done, will it work? I don't really care about the electronics, but about the mechanical fittings... Do i have tu make customised pieces to make it fit on a J30A1 ?
Old Oct 28, 2006 | 03:58 PM
H2290's Avatar
Default Re: (AuLit)
What you are asking is if the bell housing will fit up. I think it will but I am not 100% sure.
Old Oct 28, 2006 | 04:27 PM
Default Re: (H2290)
j30 used in 7th gen accords is about 1/2 in shorter so it is not likely that trans will make up unless they kept the mounting ponts the same......
Old Oct 29, 2006 | 06:20 PM
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">j30 used in 7th gen accords is about 1/2 in shorter so it is not likely that trans will make up unless they kept the mounting ponts the same......</TD></TR></TABLE>
Sooooooo...you dont know for sure then?
Old Oct 29, 2006 | 06:52 PM
Chiovnidca's Avatar
I can tell you absolutely, possitively and without a doubt that I dont know.
Old Oct 29, 2006 | 07:45 PM
AuLit's Avatar
if only my Honda mechanic could tell me... but he says "It's not stock, so... (f*ck you) i cant help you" lol
Nick_cg1
Transmission & Drivetrain
Sep 12, 2012 03:56 PM
phantom_bcw84
Oct 2, 2010 08:04 PM
0bLiViOuS
Nov 13, 2008 10:50 AM
Auto96accord
Aug 31, 2006 07:59 AM
-16V-
Oct 15, 2002 10:06 PM
