Rattle from drive side rear after disc break swap. 92 EG.
Old Oct 26, 2006 | 03:57 PM
dem0nk1d's Avatar
Default Rattle from drive side rear after disc break swap. 92 EG.
So I am hearing a rattling sound coming from the driver side rear of my buddies car. I checked all the nuts and bolts to be tighten, no issues. I've shaken the wheel back and forth. Nothing rattles... Only when your driving... Is the bearing?? If so where do I get the replacement bearing... I know it needs to be pressed in
Old Oct 26, 2006 | 03:59 PM
B16B_coupe's Avatar
HRD PKR
Default Re: Rattle from drive side rear after disc break swap. 92 EG. (dem0nk1d)
the bearing dosent need to be pressed in.. it is sold as a whole.. u just un bolt the nut.. and pull it off. and slide the new one on.. it could be the heat sheild.. or rocks in there.. plenty of things..
Old Oct 27, 2006 | 06:42 PM
dem0nk1d's Avatar
I think the sound is coming from the driverside rear brake pad. It looks to me it's missing the pad spring.... This could be a cause and will be replaced 2mro.
purple98ek
Apr 15, 2007 12:25 PM
Nova_Dust
Jan 18, 2005 06:56 PM
Kevedge
Apr 26, 2004 12:54 PM
743power
Dec 21, 2003 05:43 PM
