pedal assembly
Old Oct 26, 2006 | 03:41 PM
keepitngga1's Avatar
Default pedal assembly
my clutch pedal assembly snapped ..clutch wont engage due to the little amount being applied
any pics or write ups on how to remove the pedal assembly would be nice
90crx cable
Old Oct 26, 2006 | 03:48 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: pedal assembly (keepitngga1)
Look around for CRX Toad's info on this, I think he did a write up if not he would know how to and he also taught me and many others that the SI setup is better.
if you pm and ask nice he might help
It's pretty common to have these things go, you can also custom weld them back on.
Old Oct 26, 2006 | 03:50 PM
Tippyman's Avatar
Just take it to a shop and ask them to stitch it back up for you. Probably won't even charge you...
Old Oct 26, 2006 | 03:59 PM
89 civic si's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Just take it to a shop and ask them to stitch it back up for you. Probably won't even charge you...</TD></TR></TABLE>
usually you give good advice but you must have never worked in a shop because any mechaninc worth a damn that you dont know doesnt do anything for free especially patching something back up..mechanics in shops usually have to warranty their labor which they cant do with a patch up maybe a mom and pop shop but not just any shop.. go to the junkyard and get a pedal assembly its a bitch to do but you can get it done with some patience just remove and replace
Old Oct 26, 2006 | 04:02 PM
Tippyman's Avatar
Default Re: (89 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">
usually you give good advice but you must have never worked in a shop because any mechaninc worth a damn that you dont know doesnt do anything for free especially patching something back up..mechanics in shops usually have to warranty their labor which they cant do with a patch up maybe a mom and pop shop but not just any shop.. go to the junkyard and get a pedal assembly its a bitch to do but you can get it done with some patience just remove and replace</TD></TR></TABLE>
If you just ask them to run a weld down a crack, they probably won't make it a big deal. Depending on the place you take it to, they'd probably just treat it under the table and ask you for like $10 or sumthing.
Old Oct 26, 2006 | 04:12 PM
sounds good..but with them rewelding it,will it be more prone to break again rather than replacing it
Old Oct 26, 2006 | 04:13 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keepitngga1 &raquo;</TD></TR><TR><TD CLASS="quote">sounds good..but with them rewelding it,will it be more prone to break again rather than replacing it</TD></TR></TABLE>
I've not had any problem and my clutch is alot heavier now then when it snapped.
all in the weld.
Old Oct 26, 2006 | 04:14 PM
Tippyman's Avatar
Probably be stronger, lol. If you really wanted to go all out, weld extra metal on it.
Jonny Rocket
Oct 8, 2007 08:57 AM
BeavisB16
Jan 25, 2006 08:46 PM
4DRmafia
Jun 10, 2004 06:58 AM
jondancer
Jun 9, 2003 02:57 AM
TRE_
12
Jan 21, 2003 05:48 PM
