Suspension & Brakes Theory, alignment, spring rates....
are grade 5 bolts strong enough
Old Oct 26, 2006 | 02:12 PM
piotrush's Avatar
Default are grade 5 bolts strong enough
Hi guys, I just gos a set of metric bolts from home depot and I wanna use them to mount my strut braces to the mounts. They are stamped with 8.8 on the head. From what I know, 8.8 is the equivelant to a SAE 5 rating, is that going to be strong enough to use on strut braces? Thanks
Peter
Old Oct 26, 2006 | 02:15 PM
Tyson's Avatar
Default Re: are grade 5 bolts strong enough (piotrush)
itll be fine. its not important.
Old Oct 26, 2006 | 06:53 PM
super_nguyen's Avatar
Default Re: are grade 5 bolts strong enough (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piotrush &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, I just gos a set of metric bolts from home depot and I wanna use them to mount my strut braces to the mounts. They are stamped with 8.8 on the head. From what I know, 8.8 is the equivelant to a SAE 5 rating, is that going to be strong enough to use on strut braces? Thanks
Peter</TD></TR></TABLE>
on strut braces they will be fine, nothing but sae 8 for suspension however.
Old Oct 28, 2006 | 04:38 PM
piotrush's Avatar
Default Re: are grade 5 bolts strong enough (super_nguyen)
ok, thanks guys
benin360
Nov 3, 2011 01:49 PM
schecter
31
Dec 8, 2009 10:36 PM
satsilprelude
Apr 1, 2006 08:22 AM
D3U1LT
Welding / Fabrication
Dec 10, 2004 11:12 AM
cdrlmr
Mar 11, 2004 10:16 PM
