Suspension & Brakes Theory, alignment, spring rates....
Wheres your camber?
Old Oct 26, 2006 | 01:58 PM
Tyson's Avatar
Default Wheres your camber?
just making an informal poll.
i want to know what your camber is measured at. either with a portable bubble guage or full alignment. and i want to know how much youre lowered. just give me whatever estimate (inches, fingers, rocker height, fender to hub...whatever). its all relative anyway.
pics and alignment printouts appreciated. but not necessary.
LIST:
TunerNOOB 2000 GSR
-no fender gap, -2.4*/-1.6* front/rear, Ingalls UCA bushing camber kit maxed out for more negative camber.
-aprox 2 finger front gap, rear slightly higher, -4.0*/-1.2* with SPC UCAs up front, no rear camber correction
Chem Geek
-2.5 finger, -1*/-1*
EK k kay 1999 Civic
-no fender gap front, 1cm gap rear, H&R sport springs, FL: -2.1, FR: -2.1, RL: -2.8, RR: -3.2
no_money2supe 1993 civic
-1 finger front, 2 finger rear, Neuspeed sports/koni yellow, 17", ingalls UCA bushing ket front, 3 washer shims rear, FL: 0.18* FR: -0.45* RL: 0.03*, RR: -0.21
BrianZ DC integra (racecar)
-With 225/50/15's, 4.5" ride height (1.5" shock travel), skunk2 front camber arm, front -4.2*, rear-3.5*.
Trickturn 93 civic B series
-fender to hub, front 22.75", rear 23.25", front ingalls kit, rear shimmed, front -.8*, rear -1.4*
PatrickGSR94
-0 fender gap, 205/45-16, 16x7 wheels, -2.75*, no camber correction
importdude2000 1993 DA integra
-.5 finger gap, 205/50/16, 16x7, -2.8* front, -1.7* rear
o-man CRX
-finger and a half in front, 2 fingers in the rear, -2.7/-2.5 front, -1.5/-1.5 rear . no kits
misanthropist 94 Del Sol
-2.7*/-2.8* front -1.5*/-1.5* rear. no kits. Lowered 3-4" (tucking a bit of tire).
project22a 04 s2000
-0.6* front -1.4* rear (its adjustable stock) stock springs.
furyof4 91 civic si
-2.9*/-2.7* front, no kit; -1.5 rear, ingalls kit. (-2.0 without kit) lowered 1 finger gap.
DONT IM ME. Reply to the thread, feel free to embellish with your own story. I'm organizing this list as a summary.
Modified by Tyson at 12:08 PM 3/14/2007
Old Oct 26, 2006 | 03:09 PM
TunerN00b's Avatar
Default Re: Wheres your camber? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">just making an informal poll.
pics and alignment printouts appreciated. but not necessary.</TD></TR></TABLE>
Was previously lowered to flushed tires front and back on my 00 GSR, ended up with -2.4*/-1.6* front/rear, with an Ingalls UCA bushing camber kit maxed out adding more negative camber.
Currently, 6" ground to front side jack points, or aprox 2 finger front gap, rear slightly higher, -4.0*/-1.2* with SPC UCAs up front and no rear camber correction. I asked the tech for -3.2* in the front, but, um, yeah. Never get Sears to align your car.
Or are you only asking people who do not have camber adjusters installed?
Old Oct 26, 2006 | 03:11 PM
Tyson's Avatar
Default Re: Wheres your camber? (TunerN00b)
camber kit or not.
do you know where your camber would be without a camber kit?
the fact that you have to adjust your camber to get 4* is enough information actually.
Old Oct 26, 2006 | 05:47 PM
Mr_CRX's Avatar
well, i went through the process of typing out my whole setup, and then realized I couldn't find my printout from my last alignment.
if I find it, i'll post it up.
Old Oct 26, 2006 | 06:28 PM
Chem Geek's Avatar
Lowered to about 2.5 fingers width, alignment I got a week or so ago was around (-1) front and rear. I'll get pictures and printouts up tomorrow.
Old Oct 26, 2006 | 06:51 PM
dvp's Avatar
dvp
Default Re: Wheres your camber? (Chem Geek)
I'm curious as to why you want to know this?
Old Oct 26, 2006 | 07:35 PM
EK k kay's Avatar
Default Re: Wheres your camber? (dvp)
FL: -2.1, FR: -2.1, RL: -2.8, RR: -3.2, 1999 Civic hatchback, H&R sport springs, Koni Yellows (front on top-most circlip groove, rear on bottom-most circlip groove), no fenger gap front, ~1cm fender gap in the rear
Old Oct 26, 2006 | 07:51 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chem Geek &raquo;</TD></TR><TR><TD CLASS="quote">Lowered to about 2.5 fingers width, alignment I got a week or so ago was around (-1) front and rear. I'll get pictures and printouts up tomorrow. </TD></TR></TABLE>
tell us what car when you do. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">I'm curious as to why you want to know this?</TD></TR></TABLE>
knowledge is power.
thanks ekk
Old Oct 26, 2006 | 08:02 PM
no_money2supe's Avatar
-1993 Civic DX Coupe
-Neuspeed Sports and Koni Yellows w. 17" wheels
-1 finger gap front (on top-most spring perch), 2 finger gaps rear (on middle spring perch)
-b18b with extras in the engine bay, so that could explain why it's much lower in the front
-Ingalls UCA (not the ball joint one) camber kit up front, 3 washers shimmed under each bolt in the rear
-FL: 0.18*, FR: -0.45*
-RL: 0.03*, RR: -0.21
I just asked for everything to be aligned to specs, so I'm not sure why the right side has a lower camber (larger neg. camber) since the right side is naturally higher up to compensate for road curvatures. Anyone care to enlighten me and explain?
Old Oct 26, 2006 | 08:27 PM
BrianZ's Avatar
DC chassis. With 225/50/15's on the car I have about 4.5" of right hight (about 1.5" of travel at the shock). toe is set to 0 all the way around. Front camber is set at (most of the time) -4.2 and rear is set at -3.5.
Old Oct 26, 2006 | 08:30 PM
Tyson's Avatar
Default Re: Wheres your camber? (BrianZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ &raquo;</TD></TR><TR><TD CLASS="quote">DC chassis. With 225/50/15's on the car I have about 4.5" of right hight (about 1.5" of travel at the shock). toe is set to 0 all the way around. Front camber is set at (most of the time) -4.2 and rear is set at -3.5. </TD></TR></TABLE>
hey, youre gonna have to translate that ride height from H4 speak, to DD speak. is that no finger gap on a DC chassis? and what camber kits are you using? (doesnt HC have a ride height minimum also?? or is that just IT?)
Old Oct 26, 2006 | 11:29 PM
Trickturn's Avatar
93 civic cx hb
B series up front
Fl: -.83 camber -.03 toe
FR: -.79 camber -.04 toe
RR: -1.4 camber .03 toe
LR: -1.3 camber .03 toe
Front Ingalls camber kit adjusted all the way out or else I would have more negative camber w/ another setup.
Rear I used shims to get the camber better than the -1.9 on the left that it was @ o.O
Measured from ground to middle of fender
FR height: 22 13/16"
FL height: 22 3/4"
LR height: 23 3/16"
RR height: 23 1/4"
Any clarifications or something you would like added?
Pete
Old Oct 26, 2006 | 11:33 PM
Tyson's Avatar
Default Re: Wheres your camber? (Trickturn)
actually lets just go with finger gaps as standard. im not looking for anything precise.
Old Oct 27, 2006 | 10:09 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">actually lets just go with finger gaps as standard. im not looking for anything precise.</TD></TR></TABLE>
Who's fingers? I can get my 3 year-old to check how low I am later Why not ask for middle of hub to top of fender arch, that way finger width, and tire size don't skew the results.
Old Oct 27, 2006 | 10:11 AM
Tyson's Avatar
Default Re: Wheres your camber? (nonsense)
i know, but i dont care to be too accurate for the sake of this poll.
"fingers" is a visual indication we can all sort of relate. i cant visualize 25.3" for each car.
but like i said, feel free to embellish. give me both if you want.
Old Oct 27, 2006 | 10:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This is on my old GC's, I had about -2.75* at this height, no camber correction. 205/45-16 tires on 16x7 wheels.
So that's pretty much 0 gap. Not really tucking, just top of tire even with top of fender lip.
Old Oct 28, 2006 | 05:24 PM
importdude2000's Avatar
1993 acura integra
.5 finger gap front/Rear
Buddyclub rsd coilovers for dc2-r
Itr front fork/ITR rear LCA
205/50/16
16x7
-2.8 both fronts
-1.7 both rears
Will however be going with
-2.5 front
-1.5 rear
in favor of more caster(going to use accord rods)
Modified by importdude2000 at 7:31 PM 10/28/2006
Old Oct 28, 2006 | 05:25 PM
Tyson's Avatar
Default Re: (importdude2000)
whats special about the itr fork and control arm??
Old Oct 28, 2006 | 05:28 PM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">whats special about the itr fork and control arm??</TD></TR></TABLE>
i should put just eg.dc fork tho
just saying cuz its differnt from stock DA LCA
itr lca are needed for the isntall
Old Oct 28, 2006 | 05:37 PM
Tyson's Avatar
wait sec. i totally missed that. you have a DA, how can you install a DC LCA??? what about the radius rod?
the LCA is not needed to use the later EG/DC fork.
Old Oct 28, 2006 | 06:31 PM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">wait sec. i totally missed that. you have a DA, how can you install a DC LCA??? what about the radius rod?
the LCA is not needed to use the later EG/DC fork.</TD></TR></TABLE>
i used dc/eg front forks
i used Rear itr lca to mount the shock(since it is not like the upsidedown U shock
i think i wasnt clear on what i typed sorry
edited it
Old Oct 29, 2006 | 01:42 PM
Chem Geek's Avatar
knowledge is power.
thanks ekk</TD></TR></TABLE>
About 2.5 fingers gap at this point. Alightment was all right around -1* (can't find the sheet at the moment, when I do I'll post it exactly).
Car is '93 Civic DX HB (EH2), full DC2 suspension conversion (brakes, upper & lower arms, links, trailing arm, etc), GC/Koni (425F/350R), 15x6 LS mesh with 195/50/15, ITR sways front and rear, ASR, and no camber correction at this point.
Anything else?
Old Oct 30, 2006 | 09:54 PM
Tyson's Avatar
Default Re: Wheres your camber? (99d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99d16 &raquo;</TD></TR><TR><TD CLASS="quote">_no camber correction
_maybe 1 finger front and rear
skunk2/kyb.adj.--16x7 195/50[stretched dunlops]
its stiff i got every strut bar in it[ if you live in FLA. i got them from the drivers seat in stuart] top and bottom front and rear.
-the camber is negitive front and rear it works well for where im staying now [alot of winding roads]the tires wear well. when i was in lake worth all the straight line driving gave me bad camber ware -i had to flip my tires when i go back im getting an INGALLS kit for the front </TD></TR></TABLE>
uh, this thread is for ppl who KNOW their camber.
get an alignment done and tell us what you have then.
Old Oct 31, 2006 | 11:03 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
90 CRX Si. Koni sport/GC sleeves. About a finger and a half in front, 2 fingers in the rear. -2.7/-2.5 front, -1.5/-1.5 rear . no kits whatsoever
Old Oct 31, 2006 | 02:04 PM
gabebauman's Avatar
Default Re: Wheres your camber? (o-man)
I'll grab a printout the next time I have an alignment done. I can't believe I never have before.
