Where is 98 Accord trunk light activation switch located?
Old Oct 26, 2006 | 01:54 PM
62maxx's Avatar
Default Where is 98 Accord trunk light activation switch located?
HiYa, all... Where would the trunk lid activation switch be located for the trunk light to "turn on" when the lid is lifted? I figured I would "spot" a mercury switch somewhere on the left side, but I have not. Reason is that I cant get the light to activate when the lid is opened. (bulb is good) Also, for some reason, my "open trunk lid dash light" on the door ajar indicator glows dimly on the dash then gets bright and stays lit while driving. So I figured that the trunk light switch needed to be looked at. Thanks again!
Old Oct 26, 2006 | 02:51 PM
hondadude's Avatar
Default Re: Where is 98 Accord trunk light activation switch located? (62maxx)
I'm 90% sure it is located on the latching part attached to the deck lid. Might have to remove some trim panel to get to it.
Old Oct 26, 2006 | 09:46 PM
PnX-R's Avatar
Most of the new cars have them located on the latch itself. To be sure, just look at the trunk latch and see if you see any wires going to it. There should a connector on the latch..
Old Jul 25, 2011 | 09:36 AM
AznVamp's Avatar
The switch is actually the trunk lock. If you close the lock by hand, the trunk light will turn off.
Sorry to bring this back from the dead. I was searching for it too. Thought it might be helpful for some.
Dave1821
Apr 20, 2009 04:36 PM
93H22APrelude
Feb 9, 2005 08:46 AM
DragonBoy
Jan 31, 2005 02:12 PM
Siegfried
Jun 22, 2004 04:29 AM
georgeda
Aug 12, 2003 03:53 PM
