92-95 Civic Auto To Manual Swap Question Not The Usual Questions Help Me Please
Before you try to flame me for not searching i have searched and found tons of helpful information in the archives about this conversion but none answered my questions. I have a 94 civic ex coupe with D16Z6 motor. Im doing the 5 speed conversion. I have a 97 civic ex coupe 5 speed transmission and a 92-95 civic shift linkage. What im confused about is do i buy a 92-95 civic flywheel, 92-95 civic starter, and will the 92-95 civic shift linkage work or do i have to buy a 96-00 civic flywheel, 96-00 civic starter, or 96-00 civic shift linkage. I had the idea that most D series parts were the same??? Im so confused right now any and all help is greatly appreciated.
none ever said about u having to use ewk parts you may use either or, your shift linkage will work, u need a new ecu, leave ur gas pedal u dont need a manual one, get the manual brake pedal by removing the hitch clip and replace your fatty pedal, you need a clutch master cylinder and slave cylinder
are you sure youre ready for this swap? do more research man, sounds like you dont know ur stuff, also you need a 92-00 manual starter not just any starter
anbd your tranmisson will work just fine with eg parts, you may use a 95 flywheel u need one of those also, you have a driveplate in an automatic it wont work, all a driveplate is is a mount for the torque converter
buy a clutch for the transmisson, if the trans came out of a 97 civic ex, buy a clutch kit for a 97 ex, the kit is useful it comes with everything from the input bearing to the throwout bearing and it comes with a helpful alingment tool that you can save for other clutch jobs
i know i need a manual starter and i have all pedals, manual throttle cable (heard it was different), slave cylinder master cylinder. I have everything except my flywheel, clutch pressure plate and starter. Im so confused because i called honda today to buy the bitch pin for my 92-95 civic shift linkage and they said it wont fit on my 97 civic ex transmission saying the pins are different sizes. So thats what got me wondering would i need a 96-00 shift linkage for my 97 civic transmission
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white4doorsi »</TD></TR><TR><TD CLASS="quote">so a 92-95 civic starter will work on a 97 civic transmission with 92-95 civic flywheel????</TD></TR></TABLE>
Yes, and bitch pins are the same. Look at san leandro honda as they give part numbers and compare sizes also. I think its 8x20mm but not sure off top of my head.
Also instead of getting all the factory lines there is a good write-up on a stainless hose line from your master cylinder to slave cylinder.
I have a d-series flywheel laying around also if you want it. I only want like 20.00 to cover shipping and everything. It is in good condition.
I also have a P28 virgin ecu for a manual tranny if you need one.
I did an auto to manual conversion on a 89 accord se-i last year not that that matters.
GL
GL
everything is the same most people at dealerships dont know to much cause they think its obserd to swap parts from other year cars. a 92-95 clutch will even work for your tranny but since your getting one new just get if for 97 everything else will bolt up. i put a y8 tranny on my roomates d15b7 i used everything from the b7 even the clutch.
I am in the middle of the swap myself.....there is some serious work involved jsut so you know. Its going to be a PITA with the motor in the car.
For the pedals, you are going to have to have a friend partially pull out the brake booster and the whole steering column is going to have to be dropped.
If you have any questions, grab me on aim. I should have my swap done this weekend.
Guest
Posts: n/a
you dont HAVE to have a new ECU. Its just that if you use an automatic ECU in a manual it will throw a CEL code, but the car runs fine.
However, you cannot do the reverse by putting a manual ECU in an automatic. ECU's can be converted rather easily between manual to auto, just an addition or removal of a resistor.
As far as the mount i would guess that you need a 92-95 mount.
TheCrimsonGhost666
Mid-Atlantic (Sales)
Apr 15, 2011 10:29 AM
[Ennis_D]
Apr 5, 2006 05:27 PM
