gsr muffler on 2000 civic si
Old Oct 26, 2006 | 09:44 AM
daz101's Avatar
Default gsr muffler on 2000 civic si
Hi Im new to this site, im going to purchase a gsr muffler for my 2000 Civic Si I love the look of the muffler and love the sound, was wondering if the muffler will mount on my stock piping for my exaust system? also will this perform better?
Old Oct 26, 2006 | 10:01 AM
Vero's Avatar
Default Re: gsr muffler on 2000 civic si (daz101)
you have to modify it to fight the EM1 chassis if I remember correctly.
You wont see any power gains, only if the entire piping were to be replaced with larger diameter would you see any gains.
fmrprojects's Avatar
yes it will
Old Oct 27, 2006 | 07:16 AM
daz101's Avatar
Default Re: gsr muffler on 2000 civic si (Vero)
would i have to reposition the hooks in order for it to fit correctly?
Old Oct 27, 2006 | 07:21 AM
instrument's Avatar
what exactly does a gsr exhaust sound like?
Old Oct 27, 2006 | 09:12 AM
daz101's Avatar
Default Re: (instrument)
well when my friend had it in his car it made good can noise and i like the look of it...
Old Oct 27, 2006 | 09:27 AM
TurboTagTeam's Avatar
Default Re: (daz101)
Direct bolt on. No modification necessary.
Old Oct 27, 2006 | 09:42 AM
BauleyCivic's Avatar
Risky Business
Default Re: (TurboTagTeam)
You guys are complete idiots.
EM1 Exhuast:
GSR Muffler:
Yeah, the GSR muffler is a good idea on the Civic Si...if you want the tip to be 5" short of the bumper. I doubt they are even direct bolt-ons. An OEM muffler is an OEM muffler, they both sound the same. One that is dying and is losing sound-deadening material might sound "better," and that isn't a good thing.
The GS-R does have a nice exhaust TIP though...which you can buy for $36 here: http://www.acuraoemparts.com/d...ch=no. It bolts right onto the 99-00 Civic Si muffler
Old Oct 27, 2006 | 12:38 PM
Vero's Avatar
Default Re: (BauleyCivic)
Bauley, correct me if I am wrong.
But doesnt the GSR use the same size piping as the EM1?
I also believe the ITR exhaust is a larger piping... in either case, still no gains will be found with just an axelback
Old Oct 27, 2006 | 12:39 PM
eghatch16's Avatar
do it
Old Oct 27, 2006 | 01:16 PM
dohcVTECeg2's Avatar
Default Re: (eghatch16)
they are all 2.36 in diameter. correct me if im wrong
Old Oct 27, 2006 | 01:38 PM
Targa250R's Avatar
be professional
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">they are all 2.36 in diameter. correct me if im wrong</TD></TR></TABLE>
No. It's definitely smaller.
Old Oct 27, 2006 | 02:32 PM
BudgetBalla's Avatar
Default Re: (Targa250R)
i have a gsr muffler, with a 2000 si motor. I think the noise it makes is due to the fact i had the resonator chopped off, and had a straight pipe welded in. Clean sound On a coupe, i would think the end would need to be extended.
Old Oct 27, 2006 | 04:10 PM
Mr Hammond's Avatar
a/k/a Jomo
I will. If that were true, there would be NO POINT in buying an aftermarket exhaust as most JDM exhaust systems are 60mm/2.36".
It is actually mind boggling how much misinformation there is in this forum.
Old Oct 27, 2006 | 04:14 PM
Risky Business
Default Re: (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">It is actually mind boggling how much misinformation there is in this forum.</TD></TR></TABLE>
You're telling me
Old Oct 27, 2006 | 05:21 PM
Crank's Avatar
DB8 4 Door GSR Muffler will fit with no problems.
Old Oct 27, 2006 | 05:50 PM
Heylookits shawn's Avatar
Default Re: (Crank)
2.36 OD maybe, but not the inner diameter
i doubt if its more than 2 inches ID
Old Oct 27, 2006 | 06:24 PM
Heretic:Si's Avatar
x100
Old Oct 27, 2006 | 07:42 PM
intevic_dx's Avatar
4 door integra exhaust will fit, as already stated.
if you want to use a 2 door integra exhaust, you have to extend the mid pipe 4 inches before the first bend(after the resonator) and the extend either before or after the muffler about 4 inches or the tip will be sticking in under the bumper.
the integra muffler will bolt up to the stock si midpipe, but the tip will be tucked behind the bumper.
and yes, i know this for a fact, i had a usdm itr exhaust on my 99 si before i got my 5zigen pro racer exhaust. the 5 zige is off of a 4dr teg.
yay.
95_red_dc
Feb 4, 2009 02:36 PM
924doorEG
Jul 26, 2008 04:09 PM
bOOsT-FeIn
May 9, 2006 12:18 AM
littlecivic
Jun 25, 2002 11:44 PM
littlecivic
Jun 25, 2002 11:05 PM
