koni yellows with stock springs
Old Oct 26, 2006 | 08:53 AM
ac_attak's Avatar
Default koni yellows with stock springs
Will using koni yellows on my stock itr springs lower the ride height any? I want the height about an inch lower. Will this set up make for a smooth ride(the roads are a bit rought here).
Old Oct 26, 2006 | 08:55 AM
tartje's Avatar
Default Re: koni yellows with stock springs (ac_attak)
if you want about a 25mm drop, get some eibach springs on standard shocks
Old Oct 26, 2006 | 08:56 AM
PrinceAli132's Avatar
I beleieve the koni yellows have 3 spring perches. So if you wer to set it at the lowest spring perch, your car will be slightly lower, but probably not much more than 10-15 mm.
Ali
Old Oct 26, 2006 | 09:00 AM
ac_attak's Avatar
Default Re: koni yellows with stock springs (tartje)
hmm can you get itr specific eibach springs? The stated drop for the eibachs i have been looking at is 1.3", but that drop is based on the stock gsr ride height. So that wouldnt really be much of a difference on my itr suspension.
Old Oct 26, 2006 | 09:08 AM
tartje's Avatar
yea, i did a 5 second search on UK sites, found some for £175.99
Old Oct 26, 2006 | 09:13 AM
ac_attak's Avatar
What is the estimated drop with those?
Old Oct 26, 2006 | 10:10 AM
andyt's Avatar
I have Koni yellows on stock springs and it was about an inch drop on the lower perch.
Mine are the "older" yellows that have 2 perches.
The ride quality is not that bad, but there are places around here where its very rough.
Old Oct 26, 2006 | 10:30 AM
bender's Avatar
I run Koni yellows with stock springs at the stock heights (to be autox legal).
When I bought them 2 years ago, the koni website said: Fronts have 2 grooves. Top is stock height, bottom lowers you 30mm. Rears have 3 grooves. Middle is stock height. Top & bottom are 20mm drop or raise.
Last time I looked, their site said: Adj. spring perch can lower car approx. F & R = 25mm
Old Oct 26, 2006 | 10:47 AM
ac_attak's Avatar
Default Re: koni yellows with stock springs (bender)
So should i expect a harsh ride daily driving them on the lowest perch with the stock springs?
Old Oct 26, 2006 | 10:56 AM
92TypeR's Avatar
FSAE
Revalved Koni Yellows & stock springs - lower perch
Old Oct 26, 2006 | 11:27 AM
bender's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">So should i expect a harsh ride daily driving them on the lowest perch with the stock springs?</TD></TR></TABLE>
Mine's is my daily driver, and my konis are revalved for increased damping. IMO, no problem.
Old Oct 26, 2006 | 07:01 PM
ac_attak's Avatar
Nice, thanks guys.
Big Dog
Apr 16, 2009 07:21 PM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
cmdr430
Honda S2000
10
Apr 17, 2005 11:05 PM
edoyboy
Dec 26, 2004 09:45 AM
itrboi
Apr 26, 2003 04:40 PM
