SHiFTer
hey for the manual transmxn. . the shifter its self how do you make so its like really stiff? cause on mine its like you can put it in 1st and it will still like be loose as heck like it has a lot of play so any tips on how to modify of fix it?
Ac ouple things to look at..where the shifter bolts to the linkage seems to be a common problem, the rubber in there wears out and makes it feel like you car is in neutral in every gear...you can get the parts from honda or just get a short shifter or new shifter...next replace the shift bushings with some poly ones its really easy to do...if neither of those get the feeling you want you may want to invest in a new linkage...the "U" joint can wear out and cuase some slop you can try and fix it but there isn't really a good way to go about it and new linkage isnt to costly...HTH
Jun 17, 2005 08:00 AM
