need help !.... wheels
yea u should be able to but u might scrape the fender well. my friend had them on his hatch though and tried to do a burn out and broke an axel. he said cause they were to big and heavy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msm40 »</TD></TR><TR><TD CLASS="quote">can i put 18'' wheels on my 91 hf with out axel problems?</TD></TR></TABLE>
HA HA HA HA that is the worse thing you could ever do. You are going to kill your car doing that crap. You should not go bigger than a, IMO, 15". If this is a stock HF you are going to hate yourself. You will have all kinds of issues and it will not help your axle poping out. This is the worst idea I have seen.
Not to mention your car will be even slower than hell. Go ahead and do it, your handling, acceleration and road noise will suffer, but if it's worth it to you then
. And yes, they will rub your fender wells.
As far as the axle popping out, could be the wrong axle or when it was installed it wasn't pushed in far enough so the ring at the end didn't expand into the fitting, thus not keeping it in the case.
. And yes, they will rub your fender wells.As far as the axle popping out, could be the wrong axle or when it was installed it wasn't pushed in far enough so the ring at the end didn't expand into the fitting, thus not keeping it in the case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
I know of one idea worse, lets just say dinosaurs make horrid baby sitters..
i have seventeens on my car with 40 series tires and have never once popped out an axle had road noise rubbed the fender slowed my car down or any other thing i have heard....18's are a bit big but screw everyone and what they say you axle will no pop out from having 18's you may way to go with a 35 series tire though which could be expensive.....i ran a 15.2 in my civic si with a spare tire and jack and 17's on all the way around ihe on a d15b vtec..dont listen to these honda tech ********* do what you like screw what they think.... *********
ALIKZANBRO
Jan 18, 2008 03:40 PM
