Suspension & Brakes Theory, alignment, spring rates....
-~-~-~- Anyone ever use ITR H&R sports on a LS/GSR -~-~-~-~-
Old Oct 25, 2006 | 06:50 PM
Zion-I's Avatar
Default -~-~-~- Anyone ever use ITR H&R sports on a LS/GSR -~-~-~-~-
I just picked up a set of H&R sports for an ITR. It's stated to drop the car 1.5'' in the front and 1.3'' in the rear, but seeing how the ITR sits lower than a normal integra, anyone know how much it will drop my car? These will be paired up with koni yellows (not the sp3) if that makes a difference.
Old Oct 25, 2006 | 07:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: -~-~-~- Anyone ever use ITR H&R sports on a LS/GSR -~-~-~-~- (DC2_Junkie)
Normal Integra H&R Sport springs lower more than that, so it will probably be about the same.
Old Oct 25, 2006 | 08:10 PM
Zion-I's Avatar
Default Re: -~-~-~- Anyone ever use ITR H&R sports on a LS/GSR -~-~-~-~- (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Normal Integra H&R Sport springs lower more than that, so it will probably be about the same.</TD></TR></TABLE>
Thanks patrick, I always see your responses on threads
Well normal H&R sports lower about 1.7'' in the front and 1.5'' in the back but how much lower does an ITR sit than a normal integra? I really dont wanna be as low as I am now with my neuspeed race.
Old Oct 25, 2006 | 08:31 PM
Community Builder
My old H&R Sports lowered WAY more than 1.7"
This is how it looked:
Old Oct 26, 2006 | 07:21 AM
Zion-I's Avatar
Default Re: (PatrickGSR94)
^^ maybe cause they sagged?
BTW what are you rolling on now?
Old Oct 26, 2006 | 08:23 AM
Community Builder
Default Re: (DC2_Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_Junkie &raquo;</TD></TR><TR><TD CLASS="quote">^^ maybe cause they sagged?
BTW what are you rolling on now?</TD></TR></TABLE>
no, it was that low from day one.
I got rid of the H&R's and went with Koni Ground Control sleeves w/ 380f/450r rates. Then later I sold those and got a set of ITR springs. I set the Koni spring perches to the lowest setting and put the GS-R springs in front and the ITR rear springs in back to even out the ride height. I like it, not too harsh, still got the Koni adjustability. Although sometimes I wish it were as low as it was on GC's.
Old Oct 26, 2006 | 08:26 AM
Zion-I's Avatar
^^ wow, im really hoping my cars not that low b/c thats how low it is now with my neuspeed race springs.
Old Oct 26, 2006 | 08:28 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_Junkie &raquo;</TD></TR><TR><TD CLASS="quote">^^ wow, im really hoping my cars not that low b/c thats how low it is now with my neuspeed race springs.</TD></TR></TABLE>
that's why I got rid of them, because the spring rates were not high enough to keep the suspension off the bumpstops.
Old Oct 26, 2006 | 08:59 AM
be.twenty's Avatar
i got same issue as u had patrick..
that low from day1...
Old Oct 26, 2006 | 09:07 AM
Zion-I's Avatar
Default Re: (Nuck Chorris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuck Chorris &raquo;</TD></TR><TR><TD CLASS="quote">i got same issue as u had patrick..
that low from day1... </TD></TR></TABLE>
so should i try them on my car to see how they go or just get rid of em ? I really dont wanna sit that low, but i was contemplating between the eibach sportlines and these H&R sports. damn
Old Oct 26, 2006 | 05:43 PM
no_money2supe's Avatar
Patrick,
Kinda off topic, but did you have your rears lowered on the lowest spring perches on your Koni Yellow's? I have the equivalent Neuspeed Sports with Koni Yellow's on my Civic (fronts on the highest perch, rears on the middle perch - so factory settings), but the rears are sitting about half an inch to an inch higher than the fronts. It looks as though both your fronts and rears are at the same height. And yeah, my fronts are dropped lower than what they claim on their website.
Old Oct 26, 2006 | 08:39 PM
Community Builder
Default Re: (no_money2supe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no_money2supe &raquo;</TD></TR><TR><TD CLASS="quote">Patrick,
Kinda off topic, but did you have your rears lowered on the lowest spring perches on your Koni Yellow's? I have the equivalent Neuspeed Sports with Koni Yellow's on my Civic (fronts on the highest perch, rears on the middle perch - so factory settings), but the rears are sitting about half an inch to an inch higher than the fronts. It looks as though both your fronts and rears are at the same height. And yeah, my fronts are dropped lower than what they claim on their website.</TD></TR></TABLE>
Yep, had the same issue when I first installed my H&R Sports. So I kept the front perch on the top slot and I moved the rear perches to the lowest slot to help even it out.
It's really dumb for lowering springs to lower less in back than in front, because the car sits higher in back to begin with
Zion-I
Oct 26, 2006 09:08 AM
jetpilot
Suspension & Brakes
Jul 25, 2005 01:02 PM
98LS4dr
Mar 20, 2004 12:17 PM
non-VTEC
Jul 13, 2002 11:04 AM
