Weird Squeaking noise
Old Oct 25, 2006 | 04:53 PM
devilpuppy's Avatar
Default Weird Squeaking noise
car is a 96 exr, 5 speed.
when i'm driving, i constantly hear a weird squeaking noise, regardless of a bumpy road or not.
Also, when i turn the wheel, i hear the same weird squeaking noise, it kind of sounds like my tire is rubbing, but i'm sure its not.
those noise comes from my front passenger tire area
any help?
Old Oct 25, 2006 | 05:17 PM
DC_RaceR's Avatar
Default Re: Weird Squeaking noise (devilpuppy)
does it get louder as speed pickup?
you might want to check your wheel bearings
Old Oct 25, 2006 | 06:31 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Weird Squeaking noise (DC_RaceR)
I have the same problem on my 95 accord, same spot too. My music is usually too loud for me to hear it though. I think its my bearings.
Old Oct 25, 2006 | 06:36 PM
Playa_FL's Avatar
Default Re: Weird Squeaking noise (m1ndless)
or bearings in tranny. Get new wheel bearings first, and then go from there if the problem persists.
Old Oct 25, 2006 | 08:20 PM
devilpuppy's Avatar
Default Re: Weird Squeaking noise (Playa_FL)
no, it does not get louder with speed
sometiems when i'm comig up my driveway and i roll the tire upto the part where teh curb and driveway meet and jsut turn the wheel, it heard it.
if it is bearings.....is it recommended to do just that one? gonna search for a DIY, but roughly how long for a shop to change them?
Old Oct 25, 2006 | 08:56 PM
devilpuppy's Avatar
the squeaking noise is simliar to teh noise taht you would hear when your door hinges are not greased up
Old Oct 26, 2006 | 03:09 AM
YeuEmMaiMai's Avatar
check your sway bar bushings
Old Oct 26, 2006 | 07:31 AM
Cronousman's Avatar
if it's wheel bearing, you most likely wont be able to change it yourself...and it's not recommended for you to do it on your own with simple tools...the shops usually takes about 1-2 hours to change 1 bearing.
Old Oct 26, 2006 | 08:04 AM
tuccmiester23's Avatar
good luck on ur car
Old Oct 28, 2006 | 08:43 AM
devilpuppy's Avatar
okay, i cant figure it out....some days the noise is present, other days' its not
and if i do hear it....its usually when teh road is wet, and i only hear it when turning the wheel to the left
Old Feb 14, 2007 | 03:51 PM
turbo25rs's Avatar
I'm wondering if devilpuppy solved the problem with his car because i have the same problem and i've tried replacing the upper control arm as a shop recommended and the noise went away for only a month and i'm going nuts. i've had this noise off and on for past 5 years, but only now has it been persistent. anyone that has first hand experience please help. thank you
Old Feb 20, 2007 | 09:39 PM
Satoonxtreme's Avatar
you know what, i'm having the same problem.. this noise is driven me nuts!!! can't find it since it doesn't appear in every speed bump, rough road that I gone though. I can hear it from exterior as well but not well enough to identify the source. can it be the brushing? sounds like some parts is rubbing each other and making this sound. dang
Tony Cameron
Dec 11, 2013 06:31 AM
shane2121
Jan 19, 2013 12:31 PM
Linh.
20
Nov 18, 2005 11:49 PM
gallowmay
Aug 27, 2004 03:58 PM
BigBadBuford
Jan 8, 2004 02:00 PM
