'96 temperature guage and fan not working
Old Oct 25, 2006 | 11:54 AM
Naz88's Avatar
Default '96 temperature guage and fan not working
Hey all, just looking for a little confirmation here, I tried searching and found some good info but I am still a little unsure
short story
first temp guage was acting funny, then stopped all together, and also noticed rad was leaking at this time, replaced rad and all is well now, but the temp guage never moves and the fan doesnt come on, I also changed the thermostat and seal with the rad, so I know the thermostat is good,
my thoughts are the temp sensor is failing, causing the temp guage to fail, Im curious though if this would also cause the fan to not turn on? I just want to make sure I am on the right track as I believe I wasted money buying the new thermostat as it didnt solve any problems.
The car has 350,000Km and is a testament to the quality of a Honda as its been pretty good all its life but of course little things here and there are starting to need attention!
Any help is greatly appreciated
Old Oct 25, 2006 | 01:19 PM
Perfectionist's Avatar
Default Re: '96 temperature guage and fan not working (Naz88)
I'm pretty sure the temp sending unit and the fan switch are separate sensors. You could probe the temp gauge sending unit with an ohm meter. The resistance should be in the 200 to 400 ohm range roughly and smoothly change as the engine cools down. (or ground the connector and the gauge should peg at hot. Do this only briefly to prevent damage to the gauge)
The rad fan sensor grounds the fan circuit. If you're brave, you could pull the connector off and ground it. If the fan runs, the sensor is either bad or not getting hot enough.
Old Oct 25, 2006 | 01:31 PM
ricedout's Avatar
try replacing ur temp sensor on the back of your motor and check ur wires that run to it
torino420
May 5, 2013 08:07 AM
aasaa666
May 31, 2010 07:15 AM
walrus_07
Feb 21, 2009 10:16 PM
Rayz_Si
13
Feb 27, 2008 08:29 PM
Slava.
Apr 20, 2006 07:54 AM
