obd2 to obd1 problems
heys guys
I recently did a obd1 b16 swap that I did and re wired all the sensors including vtec and the knock sensor.I also got the conversion harness. I had problems starting the car so I took it to a shop and they said I need a 96 gsr distributor.
From my knowledge I though you just re wired all the wires from the plug to the distributor using either the obd2 plug or wiring the obd1 plug to the harness.
also they said the wiring was wrong but i thought with the rest of the sensors you just re wire them using the same colour wires... i.e IAT, TPS, o2 sensor, etc
need help badly, have a feeling the shop is screwing me over
Modified by vicsir at 4:41 PM 10/27/2006
searched and found the info for the dizzy
need some help with the wiring issue. used eg wires in my ek to rewire and extend the sensors. shouldn't be anything wrong though???
any help would be great
searched and found the answer...got the car back
It seems like its starving for fuel. I have the stock d16y7 injectors in there right now. Could I use 99-00 si/sir injectors since I use my ek obd2 harness??
thanks
thanks
sumoneEK
Aug 2, 2010 09:29 AM
egreenmachine
Feb 24, 2009 11:05 AM
