Smoke coming from valve cover
Well ive been working on getting my buddys a6 to be running like a a6 again, I already replaced the headgasket which stopped all the bad smoke coming from the exhaust now he is having the problem of smoke coming from his valve cover when removing the oil cap? bad seals??? any one have any idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawfo661 »</TD></TR><TR><TD CLASS="quote">if u only get smoke when the oil cap is off ur motor is hot and it is cold outside, its just steam
, That's what i'm thinking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Could be bad seals or a bad VC gasket. You did put a new gasket on right ?</TD></TR></TABLE>
How the hell would a bad VC gasket cause the "inside" of the motor to smoke ?
, That's what i'm thinking.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Could be bad seals or a bad VC gasket. You did put a new gasket on right ?</TD></TR></TABLE>
From: I told you to wait in the truck in Texas, United States
Some smoke is normal...
It is known as "blow-by" which is a bi-product of
the engines compression..
Compression by-passes the piston rings and pressurizes
the crankcase..That is what the PCV system is all about..
It channels the unburned gases back through the intake
to be burned again..
As long as it is not consuming mass quanties of oil
it is OK..
it is OK..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-Si »</TD></TR><TR><TD CLASS="quote">
Though about that one after I posted. This guy has a SOHC, I had a smoking problem caused by bad plug seals on my DOHC recently, oil was blowing by into the plug tube, smoking, then coming out into the head. I always change the plug seals when replacing the VC gasket, hence my association between the two. My bad for not explaining thoroughly, no need to be a dick though
, That's what i'm thinking.How the hell would a bad VC gasket cause the "inside" of the motor to smoke ?
</TD></TR></TABLE>Though about that one after I posted. This guy has a SOHC, I had a smoking problem caused by bad plug seals on my DOHC recently, oil was blowing by into the plug tube, smoking, then coming out into the head. I always change the plug seals when replacing the VC gasket, hence my association between the two. My bad for not explaining thoroughly, no need to be a dick though
I doubt its a piston ring. However, it could be bad valve stem seals. I agree that it's probably just a blow by though, but if you're worried about it then I would check the valve stem seals out.
92civichatchsir
12
Sep 27, 2005 10:07 AM
