91HB B16A no spark/main relay clicks rapidly
i have a 91 hb with a obd-0 b16a swap. the guy i got it from really messed up the wiring, so now i'm stuck tring to figure out a ratsnest. it was running until recently it died out. lost spark and now the mainrelay clicks fast. short little clicks. i checked the main relay, coil and igniter all seemed ok(i'll retest again to make sure)also replaced them with other known good ones. it makes me think somthing shorted out or is worn out. i'll check the igniton switch here today, it looked kinda janky when i put it in.(theft rebuild project) anyone ever had this happen with the main relay clicking? any suggestions?
check engine light studders in seqence with clicking,also real dimlike something is shorted to it. goes normal brightness with main relay unplugged. ecu light is also on constant. not throwing codes. no spark.
well. the main relay might click, but that does not mean it is working properly. if you used and obd0 harnes meaning that it should be almost plug and play. ig you soldered any wires check them. believe or not these are comon problems. this happened to me last year. i thought all my solders were good, but it turned out ne of my wires was hitting the chassis. just try changin the main relay and try and see if you can get a ignitor for your dizzy. unfortunatly there is too many possibilities for the problem you are trying ti figure out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">check all your grounds</TD></TR></TABLE>
thats what i did with my ef and it worked
This is what ur problem sounds like, when i did my swap i had the same issue and i found the ground from the tranny to body to have a bad ground there but i would check all urs even if that emans taking them off and using some sand paper to make that better connection.
fenix4o9
11
Jul 18, 2007 04:06 PM
