Dead End problem
Old Oct 25, 2006 | 01:27 AM
panta83's Avatar
Default Dead End problem
I search it on the forum but i found nothing ...
so I've got a prob.
I can't start my engine ... Got fuel in the fuel rail ... but the injector don't want to spit fuel .
So ... you've got a common ground for the injector clip which goes to the dead end ( at the right of the clutch liquid ).
At this dead end you've got 8 wires ... 4 are for the injectors ... Do you know for the 4 else ??? ( in those 4 else i've got 2 right and 2 which are at 1 and 1,4 v ... :s
Sorry if it's not really comprehensible but i've made my best
Thanks
Old Oct 25, 2006 | 12:53 PM
Perfectionist's Avatar
Default Re: Dead End problem (panta83)
Typically, the injectors are all fed a constant voltage. The ECU grounds them individually as required to charge the cylinders.
Old Oct 25, 2006 | 02:03 PM
panta83's Avatar
Default Re: Dead End problem (Perfectionist)
I saw and got an old problem with my old motor with the mai relay ( fuel pump wasn't working ) . But could the main relay make the injectors doesn't work ?
Old Oct 25, 2006 | 02:08 PM
It could, but your ECU would throw a code for that. Code 16 on 4th gens.
Old Oct 25, 2006 | 02:29 PM
panta83's Avatar
Thanks ...
EDIT:
Found !
I've got to try with the stock injector , another ecu and another main relay .
Is it possible that the injector are " blocked " or something ? ( brand new precision 525 cc 12ohms so on a EG6 that's ok )
Thx
Modified by panta83 at 1:44 AM 10/26/2006
turtlegrip
21
May 16, 2014 11:52 PM
rlembitz
Dec 24, 2010 09:04 AM
95CivicDx51
May 29, 2009 09:15 AM
Jmunk
Feb 17, 2006 10:09 AM
civickiller
13
Jun 25, 2004 08:25 AM
