d16z6 vs d15b vtec
Old Oct 24, 2006 | 09:44 PM
littoboypinoy's Avatar
Default d16z6 vs d15b vtec
<U>Honda Crx Si 88</U>
d15b vtec
or
d16z6
or
d16z6 block + d15b vtec head
or
d15b vtec block + d16z6 head
Old Oct 24, 2006 | 09:53 PM
VRD^don's Avatar
Default Re: d16z6 vs d15b vtec (littoboypinoy)
i believe the d15b has a bit more aggressive cam then the z6 does...i would go with d15b and turbo it!!!
Old Oct 24, 2006 | 11:25 PM
EF_9's Avatar
d15b vtec
STREETWERKZ's Avatar
Default Re: d16z6 vs d15b vtec (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote"><U><FONT COLOR="red">Search</FONT></U></TD></TR></TABLE>
bench racing is teh ghey!
Old Oct 24, 2006 | 11:27 PM
EF_9's Avatar
bench racing is teh ghey! </TD></TR></TABLE>
yeah whatever he said
Old Oct 24, 2006 | 11:29 PM
Default Re: d16z6 vs d15b vtec (EF_9)
honestly.... the 4 choices he gave are so friggan similar in power output, he might as well asked "what brand of oil can i use?"
Old Oct 24, 2006 | 11:32 PM
EF_9's Avatar
and which tranny he should use as well!
or maybe
d15b head z6 valve cover
z6 bottom end d15b internals and d15 oil filter
Old Oct 24, 2006 | 11:42 PM
90sedan's Avatar
If you have plans for boost, or plans for a build i would suggest getting the d16z6 as there is much more aftermarket support for the 1.6.
If you dont really have any plans after the swap, you can't really go wrong with either. Whichever one you have access to.
But a quick search would result in more answers
Old Oct 25, 2006 | 05:09 AM
89 civic si's Avatar
Default Re: (89-civic-DX)
the d16z6 is essentially the same motor as the d15b but you will never find a low mileage d16z6 that hasnt been beat to hell and back..turbo the d15b on low boost and you should have a 14 second car..i ran a 15.2 in my 89 si with shot tires and a slipping clutch.. the guy next to me was in a eg with a z6 and he ran a 17.8 but i dont think he was driving. you could easily get into the high 13's with a turbo d15b.... the d15b head is the same head as the z6 the ecu that the d15b comes with gives it the extra bump in horsepower...the d15b is a vx block with a z6 head with a bump in compression. you can rev the crap out of a d15 because of its short stroke
Old Oct 25, 2006 | 07:09 AM
Default Re: d16z6 vs d15b vtec (Mr.speaker)
the z6 is usually always beat to hell before someone does a swap the d15b is only 450 bucks plus shipping with low mileage...i couldnt find a d16z6 under 100k im not going to swap something with a 100k on it thats just stupid. and there is no diffrence in cams or heads for that matter beetween the z6 and the d15b it is the ecu and the bump in compression that make the d15b have more ponies
Old Oct 25, 2006 | 11:13 AM
flashedDc5's Avatar
jus get an a6 block and a d15b head that what i did and i have alot more torque than my b7 minime but im also turbo
Old Oct 25, 2006 | 11:45 AM
v8Buster's Avatar
on the same grounds, d15b vs d16y8 ????
Old Oct 26, 2006 | 11:09 AM
91SiZ6's Avatar
Default Re: d16z6 vs d15b vtec (89 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">the z6 is usually always beat to hell before someone does a swap the d15b is only 450 bucks plus shipping with low mileage...i couldnt find a d16z6 under 100k im not going to swap something with a 100k on it thats just stupid. and there is no diffrence in cams or heads for that matter beetween the z6 and the d15b it is the ecu and the bump in compression that make the d15b have more ponies</TD></TR></TABLE>
Which is why you're supposed to do a complete tune up before you swap a new engine in.
Old Oct 26, 2006 | 02:07 PM
Jonknee's Avatar
Default Re: d16z6 vs d15b vtec (91SiZ6)
wtf 5 hp difference over eachother. choose whatever is cheaper and less mileage man.
Old Oct 26, 2006 | 02:21 PM
Default Re: d16z6 vs d15b vtec (La-Quiete)
i actually saw the front clip my d15b came out of...the car had an automatic transmission and 45,000 on the clock...i cant even hear my motor run....im still running the plugs and wires the car came with lol
Old Oct 26, 2006 | 02:52 PM
Jonknee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">i actually saw the front clip my d15b came out of...the car had an automatic transmission and 45,000 on the clock...i cant even hear my motor run....im still running the plugs and wires the car came with lol</TD></TR></TABLE>haha im using the same plugs too, i cant find those plugs anywhere .
Old Oct 26, 2006 | 04:19 PM
the z6 ones work just fine as do the wires...i also used a d15z1 timing belt it is the same belt....every part for the z6 will work except the t belt....the head is the same head do not believe this crap i hear on hear about there being a better cam in the head..it is the ecu that gives this motor more hp than the z6 it has more agressive maps....the block is basically a 1.5 with vx rods and a piston of its own...i love my d15b i would never buy a junk z6 that has 100xxxx who knows miles on it..if you can verify mileage yeah buy a z6 for aftermarket support
blackEGFTW!
16
Jul 11, 2008 10:24 AM
skateboard_ej8
Jul 30, 2007 02:56 PM
JDMTuner4Life
Feb 24, 2007 07:29 AM
b20accord
Dec 8, 2006 11:21 AM
