help cant diagnose o2 sensor problem
Old Oct 24, 2006 | 09:24 PM
Pnoyej6's Avatar
* B A N N E D *
Default help cant diagnose o2 sensor problem
i have 96 ek hatch with usdm 97 gsr swap . I have cel 65 code secondary o2 sensor. All the wires are connected properly,sensor was replaced also and still code 65. I need to bar this damn thing. Please help. We weld the o2 bung on the piping after the cat and still cel. But when i put the obd1 p72 gsr ecu back on no cel, but goes back on with the obd2 p72
Old Oct 24, 2006 | 09:44 PM
Pnoyej6's Avatar
* B A N N E D *
help secondary o2 sensor is giving me a headache with the p72 obd2a ecu
Old Oct 25, 2006 | 06:14 AM
JasonST's Avatar
Default Re: (pnoytegn707)
With the obd2 ecu it looks for the secondary o2 sensor, with the obd1 ecu it only looks for the first o2 sensor, that's why it's not giving u the code with the obd1 one. Try checking the wires, make sure their going to the right ecu pinouts and check for connectivity, that should help u find ur problem.
Old Oct 25, 2006 | 02:30 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (JasonST)
we did check the wires and secondary o2 sensor is plugged in. blue goes to blue green goest to green and the 2 black goes to 2 black. What could be problem?
Old Oct 25, 2006 | 04:39 PM
HondaPartsHero's Avatar
Technical Hero
try swapping the black wires around
Old Oct 25, 2006 | 06:14 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (HondaPartsHero)
really i didnt try swapping black wires. I just wanna make sure we had to extend the wires right for the secondary o2 sensor? Since its swapped on ek hatch?
Old Oct 25, 2006 | 06:20 PM
Pnoyej6's Avatar
* B A N N E D *
hey honda parts /Are your obd2 o2 sensor harness already extended? Can i used it on my 96 ek with 97 gsr swap. Im pullling secondary o2 sensor cel code > maybe my wires are messd up when they extended them. Could i just used my secondary gsr o2 sensor heater plug and cut that and solder that into your harness you sell? What color are the 4 wires?
Old Oct 26, 2006 | 05:57 PM
Technical Hero
I can make it as long as you need, also if you buy the obd2 harness just make a note and instead of the harness I can just send you an extender harness for it, I just mailed one out for a guy yesterday
Old Oct 26, 2006 | 06:12 PM
Technical Hero
actually check my site i just added an extension harness to my listings
gsrcivic619
14
Dec 21, 2007 03:35 PM
JasinC19
Oct 11, 2007 09:47 AM
tpdc2
Sep 7, 2007 07:19 AM
nabin
Mar 16, 2007 03:11 AM
Smith Wise
Sep 25, 2003 11:38 AM
