cluster conversion question
i might try to put an integra cluster into my ej1 soon, and i was wondering if there is any way NOT to cut the plastic cover off to make it fit. i like a nice clean oem-looking fit...
thanks for your input
You are not going to get an OEM fit unless you modify the Civic bezel to fit around the Integra cluster, then custom make a plexiglass cover.
Someone did it a long time ago.
i searched and didnt find anything on it. trust me i'm a search **** too
so the oem clear plastic is out of the question?
here's some more pictures and the wiring diagram.
http://www.geocities.com/cinq1....html
i know there was someone that showed how to cut it too, but i can't find it right now. hope this helps!
thanks. that's the link i was gonna use to do it (it's in the FAQ).
BlueIntegraBoy, do you know if that is stock clear plastic, or plexi made for the cut cluster? also you can see through to the inside of the dash at the corners...if that's what i'll get using the stock cover, i'll see about making a plexi one.
Extent
Jul 21, 2002 05:19 AM
