spoon cams??????????
Old Oct 24, 2006 | 05:39 PM
j_wod2000's Avatar
Default spoon cams??????????
I've been looking for some specs on spoon sports cams. Unfortunately i can not find any info. besides recommended valve clearences. Do any of you guys have any experience with these cams or know the specs (duration and lift) of these cams.
Old Oct 24, 2006 | 06:46 PM
SkankyEJ7's Avatar
Default Re: spoon cams?????????? (j_wod2000)
theyre like barely an improvement over ctr cams, i think
maybe a nut hair difference in the specs but theyll make about the same as ctr i thimk
Old Oct 24, 2006 | 07:07 PM
allm0torGSR's Avatar
Default Re: spoon cams?????????? (SkankyEJ7)
I use Spoon cams.
Intake lift 11.53mm, duration 256
Exhaust lift 11.13mm, duration 245
Nearly identical intake and exhaust lift of Toda A's, and nearly identical intake and exhaust duration of Toda B's. Except unlike Toda's, the non-VTEC lobes are staggered to induce swirl filling of the cylinders. The non-VTEC lobes are also slightly larger than ITR and CTR's. And my idle is silky smooth.
Drag-On
Oct 17, 2002 12:46 AM
otacon
Mar 17, 2002 07:14 PM
ItRmb
Nov 4, 2001 08:05 PM
alexboy
Aug 28, 2001 08:35 PM
