Coolant Lines Looped
Old Oct 24, 2006 | 05:17 PM
lude98SH's Avatar
Default Coolant Lines Looped ..IACV
Ok I looped my coolant lines....block to thermo and IACV to itself and just vacumm capped the TB and FITV. Anyway the cars idles like crap for about 15 mins and then once its warmed up it seems to idle fine..just a bit higher like 100rpms. My question is can I just cap off the ends of IACV instead of looping a hose?
Old Oct 24, 2006 | 05:41 PM
v4lu3s's Avatar
RTFM
my iacv just sits there without hoses on it at all.
Old Oct 24, 2006 | 05:48 PM
lude98SH's Avatar
Default Re: (v4lu3s)
Hmmm...actually that makes sense there is no vacumm source i believe. But what was coolant running to it originally for....cold start ?
Old Oct 24, 2006 | 08:53 PM
94vtirozguy's Avatar
i run the coolant line form the thermostat housing to the IACV and then from IACV back to thermostat housing. EGR is blocked off (this was of course after the Skunk 2 IM install
idle is fine, no problems with it
Old Oct 24, 2006 | 09:11 PM
lude98SH's Avatar
Default Re: (94vtirozguy)
But that just helps for cold start up corect...otherwise once the car is warm the coolant lines going to the IACV and FITV are useless correct ? One thing I did notice about my idle is that its idling around 1000 rpms about 300 higher than normal.
Old Oct 25, 2006 | 12:33 PM
lude98SH's Avatar
Default Re: (lude98SH)
One problem im having is it seems the car had a hard time starting. Its been chilly in the mornings prolly mid 30s.
Old Oct 25, 2006 | 12:58 PM
bluedlude's Avatar
are you surprised that when you remove your cold start that your car has trouble starting in the cold?
Old Oct 25, 2006 | 01:17 PM
lude98SH's Avatar
Default Re: (bluedlude)
Its called the Fast Idle Thermo Valve I didnt think it had alot to do with the actual starting more so the cold idle.
Old Oct 25, 2006 | 06:35 PM
lude98SH's Avatar
Bump
Old Oct 25, 2006 | 08:17 PM
lude98SH's Avatar
So would running coolant to the IACV help anything ? Or should I remove everything ?
Old Oct 25, 2006 | 09:50 PM
well i have had no problems, and to test it, i went for a long spirited drive for a few hundred km's and no issues.
Car warms up like normal, and tuns like normal.
Old Oct 26, 2006 | 07:03 AM
lude98SH's Avatar
What climate do you live in though ? Because it gets pretty cold here.
Old Oct 26, 2006 | 08:24 AM
2lude4u's Avatar
Starting in the cold w/out an FITV can be a little challenging. I don't know what your car idles at after it's warm, but my thought would be to raise your idle 2-300 rpms when the engine is warm. Then next time you cold start see if it starts up better because it will be getting some additional air. Then when Spring comes you can drop the idle back down.
Old Oct 29, 2006 | 07:27 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">i run the coolant line form the thermostat housing to the IACV and then from IACV back to thermostat housing. EGR is blocked off (this was of course after the Skunk 2 IM install
idle is fine, no problems with it</TD></TR></TABLE>
Im thinking about trying it that way....but it still seems strange to me that it would trigger a CEL with the way I did it. Maybe because of the cold outside, maybe you can only loop the lines from the IACV when its warmer....idk.
Old Oct 29, 2006 | 03:17 PM
lude98SH's Avatar
bump
Old goat
Aug 24, 2016 10:06 AM
natebaur
Dec 27, 2009 07:22 PM
SpEeDyX
Jul 5, 2009 10:59 AM
GAccord
Jan 29, 2005 10:18 AM
X2BOARD
May 17, 2002 12:57 PM
