My First Big Build *85mm B16a*
Old Oct 24, 2006 | 05:00 PM
civicjdmb16a's Avatar
Default Civicjdmb16a Turbo SC61 85mm B16a Build
Hey everyone, i just wanted to share my recent build with everyone. Had the car since Nov 99 but never had the time or money to do a build like this. I am hoping to get 550hp to the wheels. Let me know what you think!
Engine:
B16a
Extra thick Darton Sleeves
85mm bore w/ -4cc forged pistons
Total Seal Rings
Sysc I-Beam Racing Rods with 3/8 ARP Rod Bolts
Main Line Honed
Race Port and Polish
76mm Throttle Body
Skunk2 Intake Manifold
AEM Fuel Rail
AEM Fuel Pressure regulator
Swirl Polish Valves
Multi Angle Valve Job
Diamond Milling & Resurfacing
Slightly polished Combustion Chambers
Dual Valve Springs
Titanium Retainers
GSR Cams
Adj Cam Gears
Tial 50mm BOV
Tial 44mm Wastegate
P-Fab Manifold
Ah...my turbo of choice; a SC61 w/ anti surge holes
I used a Type R oil pump and a moroso oil pan w/ rear kick out
Here she is all assembled. My old turbo is on there.(Didnt get my new one yet)
Heres the engine in the car. You can see I went with a Hydro tranny. Its from a 99 Civic Si. I had the diff welded for full time LSD.
My Wings West Kit and a 29x11x3 intercooler
This is it when it was all done.
UPDATE!!!!
I tuned with Xenocron !!!!!!!. Everything went as planned!!!!!! I hit full boost(14.5psi) @ 5200 and pulls like crazy all the way up to 9200rpm's
Wastegate is set at 14.5psi for the street and 26psi at the track with DSS stage 3.9 axles and 24.5" Hoosier slicks. We'll see what happens! I will post more pics when i can.
Modified by civicjdmb16a at 3:13 AM 11/7/2006
Modified by civicjdmb16a at 1:07 PM 11/24/2006
Modified by civicjdmb16a at 6:13 PM 1/13/2007
Modified by civicjdmb16a at 7:27 AM 2/10/2007
Modified by civicjdmb16a at 10:56 AM 2/17/2007
Modified by civicjdmb16a at 11:58 AM 2/17/2007
Old Oct 24, 2006 | 05:01 PM
Pee Wee's Avatar
Default Re: My First Big Build *85mm B16a* (civicjdmb16a)
Old Oct 24, 2006 | 05:07 PM
4cefedcrx's Avatar
Default Re: My First Big Build *85mm B16a* (Pee Wee)
nice setup. I never knew you could weld your differential to make all time LSD. anyone have any pros and cons of welding it?
Old Oct 24, 2006 | 05:13 PM
STREETWERKZ's Avatar
Default Re: My First Big Build *85mm B16a* (crex89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex89 &raquo;</TD></TR><TR><TD CLASS="quote">nice setup. I never knew you could weld your differential to make all time LSD. anyone have any pros and cons of welding it?</TD></TR></TABLE>
snapping axels, blowing up transmissions.
but does it work? hell yes it does!11!!!
Old Oct 24, 2006 | 06:05 PM
crxpwr1's Avatar
Default Re: My First Big Build *85mm B16a* (STREETWERKZ)
Damn I love seeing a b16 built...
Iron_Forrix's Avatar
i take it your going to be using Vault energy drinks on your car to supplement the turbo, like in the 5th pics lol.
Really nice stuff dude.
Old Oct 24, 2006 | 06:15 PM
SpooledT3's Avatar
Default Re: (Iron_Forrix)
nice build man, love that turbo
Old Oct 24, 2006 | 08:25 PM
KFBhonda's Avatar
nice.
but you do realize that a welded diff is for DRAG ONLY, because when you turn with it, you will break stuff
Old Oct 24, 2006 | 08:32 PM
wfocrx's Avatar
you would think since you spent a crazy amount of $$$ to build everything right you would just get a real LSD.
but, props on the build it should be a beast
Old Oct 24, 2006 | 08:34 PM
Tippyman's Avatar
Cool.
Old Oct 24, 2006 | 08:35 PM
Default Re: (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote"> real LSD.
LIMITED slip differential.
welded gears = NO slip.
Old Oct 24, 2006 | 08:40 PM
crx2nr822's Avatar
Default Re: (STREETWERKZ)
Nice project!!!
Old Oct 24, 2006 | 09:54 PM
ED9man's Avatar
A welded diff is a stupid idea for the street. An LSD does the same thing a lot better.
Old Oct 25, 2006 | 03:34 PM
Default Re: (ED9man)
well this car is not gonna be used on the street that much, and i have a few friends that had the diff welded and its a little hard to drive on the street (turning is hard) but i was willing to deal with that. I never heard of breaking anything just by turning. My buddy went from a 1.9 60ft(LSD) to 1.6 60 ft w/welded diff. Its the same thing as a racing spool. Thanks for the props
Old Oct 25, 2006 | 03:44 PM
powermanaf's Avatar
looks like fun.
Old Oct 25, 2006 | 04:13 PM
Jonknee's Avatar
Default Re: (powermanaf)
looks awesome dude, very clean.
Old Oct 25, 2006 | 04:43 PM
joethejoeman's Avatar
Default Re: (La-Quiete)
damn
Old Oct 25, 2006 | 04:49 PM
Tippyman's Avatar
Noob question, but what the **** are anti-surge holes?
Old Oct 25, 2006 | 05:13 PM
uberhaulin's Avatar
very nice, keep up the good work
Old Oct 25, 2006 | 05:21 PM
b20turboic's Avatar
Not too bad man. Nice setup
GET RID OF THE WELDED DIFF
You do know what happens if you break an axle dont you?? You go flying into the wall in the other direction at what ever speed you are going. BAD IDEA
But 550 should be capable with that turbo .. My 84mm LS setup with an ls head did 500whp on the 60-1 with 26 psi.
Old Oct 25, 2006 | 06:05 PM
Jonknee's Avatar
Default Re: (b20turboic)
Im gonna guess the littles holes are for releasing pressure. Sort of a blow off valve sorta deal?
Old Oct 26, 2006 | 03:31 PM
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Noob question, but what the **** are anti-surge holes?</TD></TR></TABLE>
It is supposed to increase efficiency at high boost/airflow levels by not surging
Old Oct 26, 2006 | 03:46 PM
s10cky's Avatar
nice.
Modified by s10cky at 2:54 PM 11/4/2006
Old Oct 26, 2006 | 03:50 PM
WillieWillieFast's Avatar
Looks nice.
Old Oct 26, 2006 | 04:19 PM
Deetz's Avatar
Crazy Honda Guy
Looks like a nice build. You do know that all b series vtec oil pumps are the same? The Type R uses the same one the b16a and gsr does.
