rear disc brakes convertion in civic EK4 - 96 coupe??
Old Oct 24, 2006 | 03:09 PM
loverboy's Avatar
Default rear disc brakes convertion in civic EK4 - 96 coupe??
Hi and good evening folks !
Im going 2 convert my rear civic ek4 brakes into disc brakes !
I know that any civic SI 99-00 and integra 94-01 kit will work.
but what is the best choise ??
is there a difference between the ITR, GSR, LS or civic SI brakes (Like disc diameters caliper strength) ??
If there is a difference who is the best ??
need ur help !
Thanks.
Old Oct 25, 2006 | 02:40 PM
loverboy's Avatar
Default Re: rear disc brakes convertion in civic EK4 - 96 coupe?? (loverboy)
Hi !
I want 2 purchse the brakes kit !
I could use some help !!
Thanks !
Old Oct 25, 2006 | 03:30 PM
MessGSR's Avatar
There is no difference in rear disc...they are all the same wether it be 99-00 si, or 91 integra all the same.....u need a 99-00si prop valve, u also need to use the ek crontrol arms, and the integra trailing arms These are a must or ur camber and toe will be off.
Old Oct 25, 2006 | 08:27 PM
loverboy's Avatar
Default Re: rear disc brakes convertion in civic EK4 - 96 coupe?? (MessGSR)
Thanks very much !!
Do i need the booster and the master cylinder too ???
If the prop valve is needed, do i need the si 99-00 or the Integra valve??
Thanks !
Modified by loverboy at 12:39 PM 10/26/2006
Modified by loverboy at 5:19 PM 10/26/2006
Old Oct 26, 2006 | 12:29 PM
MessGSR's Avatar
u only can use the 99-00 si prop valve....and if u want u can also use the 99-00 si master cylinder...only use 99-00si parts
Old Oct 26, 2006 | 05:21 PM
loverboy's Avatar
OK !
The prop valve only from the si 99-00.
But can I use the master cylinder and booster from the integra ?? (I have an offer with the hall kit).
Can I use my original (EK4 96 civic EX coupe with ABS) master cylinder ??
Another qustion is: should i buy the integra ABS units (rear discs) or I can reuse my units ??
Modified by loverboy at 2:13 AM 10/27/2006
Modified by loverboy at 9:08 AM 10/28/2006
Old Oct 28, 2006 | 03:03 PM
loverboy's Avatar
Guys !!
I bought the kit and i have 2 know what 2 ask from the seller !
Please respond 2 the questions below !
thanks and have a good weekend everybody !
Old Nov 2, 2006 | 11:58 PM
loverboy's Avatar
Guys I steel need some help here !
Should i buy the integra ABS units (rear discs) or I can reuse my units (EK4 96 civic coupe) ??
Thanks.
Old Nov 5, 2006 | 11:14 AM
MessGSR's Avatar
b more specific plz
Old Nov 6, 2006 | 12:29 PM
loverboy's Avatar
I understood that every wheel have an abs unit (tell me if im wrong).
So when swapping the rear drums in my civic into discs should i replace the abs units as well?
Old Nov 6, 2006 | 01:24 PM
SiRek4
Guest
Posts: n/a
i have a set of rear disc brakes with skunk2 wheel studs and control arms, im selling them for $225.00
includes full brake assembly
brake booster
15/16 master cylinder
4040 proportioning valve
the only thing you will need to get is the ebrake cables.
Old Nov 7, 2006 | 12:36 AM
EK-Chris's Avatar
Default Re: rear disc brakes convertion in civic EK4 - 96 coupe?? (SiRek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote">There is no difference in rear disc...they are all the same wether it be 99-00 si, or 91 integra all the same.....u need a 99-00si prop valve, u also need to use the ek crontrol arms, and the integra trailing arms These are a must or ur camber and toe will be off.</TD></TR></TABLE>
You do NOT need an SI prop valve to do a rear disc brake swap. The stock one in your car is fine. I put Del Sol rear discs on my 96 HB, and still retained the stock prop valve. I even upgraded my front brakes to ITR spec and still kept it. I did upgrade the master cylinder to a 1 inch (vs stock 13/16). Its not necessary with the swap you are doing.
I used
1. 95 Del Sol trailing arms
2. Stock CX lower control arms
3. 95 Del Sol e-brake cables
Everything bolted up fine. Your camber will not be thrown off by much if you line everything up with what came off. If you are that worried about it- get an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loverboy &raquo;</TD></TR><TR><TD CLASS="quote">I understood that every wheel have an abs unit (tell me if im wrong).
So when swapping the rear drums in my civic into discs should i replace the abs units as well?</TD></TR></TABLE>
To my knowledge ABS units in Civic and Intergras are ONLY in the front. There will be a ring with slots/grooves in the area where the axle goes into the hub. That is the area that the ABS sensor reads. I dont think Rear disc brakes (Civic/Integra) have this. You will have to check. I am using Integra front hubs on my Civic and they work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote">u only can use the 99-00 si prop valve....and if u want u can also use the 99-00 si master cylinder...only use 99-00si parts </TD></TR></TABLE>
You can use Integra prop valves as well. Make sure the hardened lines bolt up in the same location. Its not unheard of to use GSR/LS brake parts. (99-00 Si works to) You dont have to only use 99-00 Si parts.
ek four
Northern California (Sales)
May 27, 2013 06:52 PM
gabbernaut
Aug 22, 2012 10:58 AM
rediye
May 9, 2009 11:04 AM
Fugeeu
Aug 11, 2004 12:26 AM
lk0
Apr 13, 2003 08:16 PM
