Some rattling noise inside my car
Old Oct 24, 2006 | 03:03 PM
ck123's Avatar
Default Some rattling noise inside my car
When i go over tiny bumps i can hear some rattling/clacking noise coming from the front of the car. THe noise goes away when i press on the brakes..if that helps. It seems like something is loose. Anyone know what it is?
Old Oct 24, 2006 | 04:32 PM
mrtoastyjr's Avatar
Default Re: Some rattling noise inside my car (ck123)
is it kind or a clunking from the right front, almost underneth the passengers feet?
if so then its most likley the rack end bushing. i just replaced mine, no more noise and i also had a highway speed shimmy that also went away
Old Oct 24, 2006 | 08:17 PM
ck123's Avatar
Default Re: Some rattling noise inside my car (mrtoastyjr)
yup
its coming somewhere from the front....
1.how much would it cost to replace?
2.Whats the worst case scenario if i dont replace it?
3. and is rack end bushing also known as the steering rack bushing?
Old Oct 25, 2006 | 12:44 PM
ck123's Avatar
anyone help?
Old Oct 25, 2006 | 01:19 PM
rsca_crx's Avatar
Default Re: (ck123)
noone is going to really be able to solve this one for you, especially based on the information provided- get the car up in the air and have a look.
with that said, if it is a thin metallic clanking/ rattle from the front as you described that is fairly constant and goes away when braking, it definately 'aint the RE bushing. i'll put my nickel on a loose cat heat shield. who wants to raise me? if you can move the shield (the spot welds rust through pretty predictably) just rip the sob off.
if it is a more solid and low "clunk", have a look at the ball joints, radius rod bushings, and other subframe/ suspension bolts and bushings.
RG5384
Apr 29, 2013 12:59 AM
JDMPR
Mar 25, 2013 08:40 PM
qhondak
Oct 6, 2009 10:17 PM
Crosser
26
Jan 16, 2002 06:35 PM
Gen5_EG
Nov 10, 2001 09:05 AM
