Mugen Thermostat and fan switch
anyone have any expierence with these, my car take FOREVER to warm up. Would this be a good upgrade, or is it for race application prettymuch?
your t-stat is probably bad (stuck open) if it takes forever to warm up. You'll know for sure if the the temp fluctuates depending on engine load. It will fluctuate from normal to cold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco »</TD></TR><TR><TD CLASS="quote">your t-stat is probably bad (stuck open) if it takes forever to warm up. You'll know for sure if the the temp fluctuates depending on engine load. It will fluctuate from normal to cold.</TD></TR></TABLE>
Yeah, this is probably the problem. I had the same issue, so I went out and bought a thermostat replaced it. No longer have that issue.
anyone know the thermostat part #? i'm looking on Baranco Acura now but can't find a thermostat anywhere!!!
EDIT: FOUND IT!!!
Modified by Ill Mitch at 8:54 AM 10/25/2006
EDIT: FOUND IT!!!
