Help : y8 block z6 head
Old Oct 24, 2006 | 10:44 AM
viskii420's Avatar
Default Help : y8 block z6 head
I did my search but i cannot relle find what im looking for... planing to do mini me swap on y8 engine.. puttin a z6 haed..
Things that i know:
i have to ADVANCE the y8 cam w/ the z6 gear 4.5 degrees.
i need obd1 distribud.
p28 ecu
1 head stud from the z6 head
OBD2a to OBD1 conversion for the ECU
Things that i dont know:
which injectors do i use OBD1 or OBD2a or they are the same " if OBD1 injectors are to be used are this bolt on or wat wiring do i need"
how do i wire the OBD1 distributor to OBD2a engine harness
what Timing belt do i use
Thanks for help in advance...
"Having a build z6 head is the reason that i do this mini-me"
p.s. Please state if u have any input that i will face with this frankestien
Old Oct 26, 2006 | 10:56 AM
viskii420's Avatar
anyone..
Old Oct 26, 2006 | 11:03 AM
Sleepy_Red_hatch's Avatar
Default Re: (viskii420)
uhhh are you sure you need a OBD1 dizzy? im PRETTY sure (not 100% thogh) that you can use ANY d-series Vtec dizzy with any D series head as long as the obd works with your set up, i think your Y8 dizzy will fit on it, and if it does, use the Y8 injectors aswell.
Old Oct 26, 2006 | 11:05 AM
D16Y8-JDMYO's Avatar
Default Re: (Sleepy_Red_hatch)
my injector harnesses on my y8 didnt fit my z6
Old Oct 26, 2006 | 11:07 AM
Marauder's Avatar
Default Re: (D16Y8-JDMYO)
That's not a mini-me swap. A mini-me is putting a VTEC head on a non-vtec block.
Are you just doing it as a cheap replacement head? There isn't much difference between the two to really go thru all that work.
Old Oct 26, 2006 | 11:23 AM
viskii420's Avatar
i just did a cheap swap.. y8 longblock..got rid of y7... used all the harness from the ex .. everything is fine.. vtec engadges the motor is fine... but before the motor came along my idea was to do a mini me on y7 w. the z6... so i started buying z6 head did custom P&P, turbo stage2 y8 cam ,vavles,springs ext.. so having all this item's was wondering what else do i need to get to make the right head exchange or (w.e u wana call it) i consider my self as a noob even i have some knowledge about car's...
as from the replays that i got...
all what i need is OBD1 ecu? y8 dist and injectors would be fine?
thanks in advance
Old Oct 26, 2006 | 07:50 PM
viskii420's Avatar
anyone please
Old Oct 27, 2006 | 06:27 AM
HoNda PriNcess's Avatar
Default Re: Help : y8 block z6 head (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 &raquo;</TD></TR><TR><TD CLASS="quote">I did my search but i cannot relle find what im looking for... planing to do mini me swap on y8 engine.. puttin a z6 haed..
Things that i know:
p28 ecu
Old Oct 27, 2006 | 06:32 AM
Things that i know:
p28 ecu
You need Y8 injectors, Y8 IM, and Y8 TB. Especially the Y8 injectors because they are designed to work with the VTEC OBDII ECU. You might run lean otherwise.
Old Oct 27, 2006 | 08:24 AM
viskii420's Avatar
but since.. i be changin the ecu to obd1 p28 and get only conversion from obd2a-obd1 wires.. and as for the dizzy and injectors.. i would get the clips from obd1 and just gheto wire them.. would that be okay? or i be runnin in trouble w. codes on ecu?
Old Oct 27, 2006 | 09:51 AM
viskii420's Avatar
boing..
Old Oct 27, 2006 | 09:54 AM
Bense's Avatar
leave the cam where it is, use 1 z6 headbolt where the vtec soleniod is, and the rest use y8 head bolts.
either use a dialback timing gun to set timing to 16btdc or run the z6 crank pulley or bust out the protractor and make your own timing marks.
Old Oct 27, 2006 | 10:01 AM
viskii420's Avatar
i'm goin to use y8 stage 2 turbo cam from crower.. i got venom cam gear would that help if i just advance to 4.5 degree
Old Oct 27, 2006 | 10:03 AM
Bense's Avatar
i've seen that thread. don't worry about it. run an obd1 p28 ecu and get it tuned. When tuning, start with the p28 basemap z6 and not the p2p y8 basemap.
set timing to 16BTDC. and leave the camgear at 0
Old Oct 27, 2006 | 10:07 AM
viskii420's Avatar
Modified by viskii420 at 11:28 AM 10/27/2006
Old Oct 29, 2006 | 05:52 AM
viskii420's Avatar
wiring question... since there is only primary o2 sensor and no secondary on 0bd1 what change would i make?
Old Oct 29, 2006 | 08:33 AM
Skunk.Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 &raquo;</TD></TR><TR><TD CLASS="quote">wiring question... since there is only primary o2 sensor and no secondary on 0bd1 what change would i make?</TD></TR></TABLE>
Deal with the CEL or run a chipped ECU and disable the secondary o2
Old Oct 29, 2006 | 09:01 AM
buky9's Avatar
i don't think a y8 dizzy will fit on the z6 head. i have tryed it
toolbox21
Jul 21, 2008 07:29 PM
99_itr
13
Dec 24, 2007 10:24 PM
Super Chicken
Mar 7, 2005 06:15 PM
mengy007
Jan 25, 2005 02:46 PM
hondacru27
Feb 12, 2004 02:55 PM
