inner tie rod...
it's not that hard just go and buy the boots from a good company like moog or perfect circle, and some clamps or zip ties. then youll need a pickle fork (for the outer tie-rod) or a good size heavy hammer. your gonna have to remove the outer tie-rod so you'll also need a 19mm wrench for the lock nut on the outer tie-rod. once the outer is off slide the old one off and put the new one in. hope this helps.
