clutch
Old Oct 24, 2006 | 12:48 AM
EFresh's Avatar
Default clutch
we put a new clutch in and it makes a weird noise when i step on the clutch pedal all the way down. sounds like a grinding noise. car drives great. any help will be apreciated. its a obd1 ls motor.
clutch, pressure plate, pilot bearing, throw out bearing, fluids are new. torqued to spec, everything
Modified by EFresh at 2:06 AM 10/24/2006
Modified by EFresh at 2:08 AM 10/24/2006
Old Oct 24, 2006 | 01:19 AM
EFresh's Avatar
Default Re: clutch (EFresh)
Old Oct 24, 2006 | 08:16 AM
EFresh's Avatar
Old Oct 24, 2006 | 08:18 AM
Furyof4's Avatar
Cable or hydro? What clutch did you use?
Old Oct 24, 2006 | 08:42 AM
EFresh's Avatar
Default Re: clutch (Furyof4)
hydro. about the clutch, i got it with no name on it. not sure of which clutch it is.
Old Oct 24, 2006 | 09:28 AM
Ass$nyper's Avatar
Pirate General...YARRRR
first thing i'm wondering is the piolet bearing myself.
Old Oct 24, 2006 | 09:36 AM
EFresh's Avatar
Default Re: clutch (Capt. Blonde Beard)
when we replaced it, it was in pretty deep, seems like to the max. also lubed.
Old Oct 24, 2006 | 09:37 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFresh &raquo;</TD></TR><TR><TD CLASS="quote">when we replaced it, it was in pretty deep, seems like to the max. also lubed.</TD></TR></TABLE>
Does it sound like its tranny grinding or clutch grinding or can you not tell?
Is it from just pushing clutch in or is it from trying to grab a gear?
Old Oct 24, 2006 | 09:40 AM
EFresh's Avatar
it soundslike the clutch. it only makes a noise when i push the clutch pedal in. when it grabs gear it seems fine.
uVTECiVTEC
Jul 22, 2011 12:35 PM
5.56
Jan 17, 2009 06:32 PM
H.crx-si
Jul 31, 2004 06:27 PM
killerslp
Jan 25, 2004 05:35 PM
Tad
16
Oct 9, 2003 07:44 PM
