Worth port matching IM to P & P head?
Old May 5, 2002 | 03:21 PM
InfamousRS's Avatar
Default Worth port matching IM to P & P head?
I just bought a port and polished b16 head yesterday. It included a stock b16 intake manifold. I heald the IM gasket(which is exact with the head) up to the intake manifold, and it is a little off on the top where the injectors are. Would it be worth taking a dremel to it and make it the exact same size, and also smothing out the casting as far up the runners as I can?
Old May 5, 2002 | 05:06 PM
CRX_VTEC's Avatar
Default Re: Worth port matching IM to P & P head? (BLK94RS)
Damn... labor for P&P is always so expensive. I'd spend the money in a ITR manifold instead.
Old May 5, 2002 | 07:27 PM
InfamousRS's Avatar
Default Re: Worth port matching IM to P & P head? (CRX_VTEC)
I would do it my self. Id just make sure the ports are the same size, and smooth out the runners, and maybe the plenum if I feel motivated enough.
Old May 5, 2002 | 07:43 PM
Ltech's Avatar
Default Re: Worth port matching IM to P & P head? (InfamousBRS)
I bought the Port and Polish kit for $65 and it is worth it. Take your time and don't go crazy with the grinder. Here is the link http://www.theoldone.com/articles/b16a.head/ Good luck.
jason phan
Old May 5, 2002 | 07:49 PM
InfamousRS's Avatar
Default Re: Worth port matching IM to P & P head? (Ltech)
Where did you get the P & P kit?
Old May 5, 2002 | 08:12 PM
GokuSSJ4's Avatar
Default Re: Worth port matching IM to P & P head? (RSVtec)
go with an itr IM is worth it !
Old May 5, 2002 | 08:48 PM
InfamousRS's Avatar
Default Re: Worth port matching IM to P & P head? (Spoon1)
I plan on it, I wont be able to right off the bat, Im gong to have to use the b16 manifold for a while.
Old May 5, 2002 | 11:51 PM
ILOVEGIRLS's Avatar
Default Re: Worth port matching IM to P & P head? (InfamousRS)
i could have swron i read somewhere that u should port the intake manifold ports larger than the ones at the head..for some kind of anti-revision.
i could be wrong...does anyone know about this?
Old May 7, 2002 | 04:29 AM
Ltech's Avatar
Default Re: Worth port matching IM to P & P head? (ILOVEGIRLS)
I got the kit on Mac tools truck.
Old May 13, 2002 | 12:49 AM
ILOVEGIRLS's Avatar
ShawnR
Apr 9, 2007 11:22 AM
2ndgent3g
Nov 25, 2004 09:20 PM
See Are X
15
Jun 11, 2004 05:16 PM
serequis
Apr 2, 2003 09:44 PM
itr1236
Jul 18, 2001 06:47 PM
