difference between front camber arm and ball joint...
Old Oct 23, 2006 | 11:22 PM
osuperjohno's Avatar
Default difference between front camber arm and ball joint...
i was wondering what's the difference between front camber arm and ball joint...are they same? do i need them both? what's better? any help is appreciated, thanks!
Old Oct 24, 2006 | 10:44 AM
Hawkze_2.3's Avatar
Default Re: difference between front camber arm and ball joint... (osuperjohno)
What do you mean by camber arm and what ball-joint are you referring to???
Old Oct 24, 2006 | 07:08 PM
lxaccord51oxl's Avatar
Default Re: difference between front camber arm and ball joint... (Hawkze_2.3)
i think he meant by the front A arm or the front ball joints
Old Oct 24, 2006 | 07:36 PM
AJ06's Avatar
Most likely
Old Oct 24, 2006 | 09:57 PM
Default Re: (AJ06)
yea, so what's the difference?
Old Oct 24, 2006 | 11:15 PM
iam7head's Avatar
Default Re: (osuperjohno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osuperjohno &raquo;</TD></TR><TR><TD CLASS="quote">yea, so what's the difference?</TD></TR></TABLE>
it's two different part, but in tipical honda fashion, they are welded together.
your UPPER control arm is one piece with your upper ball joint.
so what's the difference? it's like asking what's the difference between an orange and apple.
Old Oct 25, 2006 | 12:24 PM
Default Re: (iam7head)
so...if i dropped my car, do i need a ball joint or the arm?
Old Feb 11, 2007 | 11:09 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osuperjohno &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering what's the difference between front camber arm and ball joint...are they same? do i need them both? what's better? any help is appreciated, thanks!</TD></TR></TABLE>
without a picture of the items said here is the best i can do.
the upper ball joint is pressed into the arm, so camber kit only comes with a ball joint which you need to press it out and press in the new unit.
the other/more expensive set up is a complete replacement of arm and ball joint, the pro about this is that you can just bolt on this piece and not having to wait for it to pressed out. after adding the shop fee, it might comes out to be the same amount of money
Old Feb 12, 2007 | 12:06 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
If you plan on lowering the car it's advised to get a front and rear camber kit. Your ball joints are already on the car so is the upper control arm, however if they are in need of replacing then I would get them replaced
AllMtorEg
Suspension & Brakes
Mar 31, 2008 08:34 AM
redej878
Suspension & Brakes
Feb 16, 2008 05:03 AM
solerizr
Suspension & Brakes
Sep 18, 2006 01:28 PM
Options
Aug 6, 2006 09:15 PM
