Idle revs
Old Oct 23, 2006 | 10:16 PM
AJ06's Avatar
Default Idle revs
My 95 Accord EX revs up/down only when Its on neutral or park... I have an auto, and I still dont know why id does that. It goes to about 1800 rpms then drops to about 600... then goes up again, then down.
Im guessing very roughly at what rpm's it revs up/down to but u get the point. WHEN I press all 4 windows to go up, it sometimes stops....
And SOmetimes, it doesnt do it at all... maybe its weather related?
Old Oct 23, 2006 | 10:47 PM
gosu08's Avatar
Default Re: Idle revs (AJ06)
i have this prob too. it just went cold here so maybe thats the prob
Old Oct 24, 2006 | 09:16 AM
AJ06's Avatar
BUT it also does it in the heat... a lot.... ands sometimes it doesnt.. hmmm
Old Oct 24, 2006 | 11:09 PM
AJ06's Avatar
AS soon as I turn on my car it doesnt do it... after I run it for a while then put it in park or neutral it does it... Boo... and its from aboit 1100 RPM's to 1900 RPM
Old Oct 27, 2006 | 09:45 PM
H2290's Avatar
As far as using the windows during this goes it is probably just electrical draw from the motors causing the alternator to load up the engine and change the idle.
For the actual problem you may want to search for idle air control valve or IACV. It senses airflow and adjust the idle accordingly to keep it smooth. But when the valve gets clogged it starts to jump around. It is located on the throttle body and very easy to clean.
Old Oct 27, 2006 | 11:34 PM
AJ06's Avatar
Default Re: Idle revs (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">As far as using the windows during this goes it is probably just electrical draw from the motors causing the alternator to load up the engine and change the idle.
For the actual problem you may want to search for idle air control valve or IACV. It senses airflow and adjust the idle accordingly to keep it smooth. But when the valve gets clogged it starts to jump around. It is located on the throttle body and very easy to clean.</TD></TR></TABLE>
Please continue on the cleaning part...
Old Oct 28, 2006 | 10:11 AM
YeuEmMaiMai's Avatar
clean your idle control valve after you verify that you do not have any vaccum leaks. it works 99.9% of the time
Old Oct 28, 2006 | 12:19 PM
H2290's Avatar
If you look on the front of your intake manifold right by the throttle body you will see this nearly rectangular looking valve that has 2 small coolant hoses entering it and 2 12mm or 14mm (can't remember which) holding it on. You just remove the hoses and pull the thing off. You then want to use some brake cleaner or something and just spray all into the thing until black crap stops coming out.
Old Oct 28, 2006 | 01:03 PM
rpc1's Avatar
Default Re: (H2290)
Can anyone help to identify the shop where we can get the gaskets for the IACV (idle Air Control Valve). I searched at AdvancedAutoParts, but no luck. Any suggestions appreciated.
Old Oct 28, 2006 | 01:07 PM
cupcke's Avatar
Default Re: (rpc1)
Mine has just started doing this also, since the weather has been colder, it does it when I 1st start it up...I have a 94 btw
Old Oct 28, 2006 | 01:54 PM
TOAB's Avatar
Default Re: (rpc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpc1 &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone help to identify the shop where we can get the gaskets for the IACV (idle Air Control Valve). I searched at AdvancedAutoParts, but no luck. Any suggestions appreciated.</TD></TR></TABLE>Did you go to their crappy site, or stop in at a store?
Old Oct 28, 2006 | 02:16 PM
H2290's Avatar
Default Re: (TOAB)
Their site is garbage, you should go into the store if you want the gasket. BUT I have not had any reason to replace the gasket unless it is damaged. Usually it is in perfectly reusable condition.
Old Oct 28, 2006 | 06:38 PM
rpc1's Avatar
Default Re: (H2290)
I went to the advanceautoparts store also, for the gaskets for IACV, with no luck. Normally practice would be to use fresh gaskets if any assembly is detached to ensure no leakages occur. My Accord is EX 6 cylinder, I understand I may have to remove the throttle assembly before I can remove the IACV for cleaning or replacement. Not sure how complex it would be for EX V6.
Old Oct 28, 2006 | 06:41 PM
rpc1's Avatar
Default Re: (H2290)
Any thoughts about the complexity involved, if I like to clean the IACV on my own.
Old Oct 28, 2006 | 09:52 PM
AJ06's Avatar
Im..... slightly confused.
Old Oct 29, 2006 | 08:52 PM
AJ06's Avatar
its sooo weird... erratic idles
Old Nov 6, 2006 | 11:59 PM
AJ06's Avatar
AAaaahhhh
Old Nov 7, 2006 | 12:54 PM
srandomuherom's Avatar
Default Re: (AJ06)
i have the same problem with my 96 honda accord ex its a 5 speed and i talked to the seller who i bought it from and he was talking about a plate that wasnt seated correctly can ne one explain wat he was talking about?
Old Nov 9, 2006 | 12:26 AM
AJ06's Avatar
The idle control valve....
Gonna clean it and ****...
The ALLAN type key on the IAC ... whats that do?
Old Nov 9, 2006 | 12:45 AM
Default Re: (rpc1)
i would just use the RTV make a gasket stuff..........
Old Nov 10, 2006 | 01:40 PM
AJ06's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">i would just use the RTV make a gasket stuff..........</TD></TR></TABLE>
Please explain....
And My idles weren't going crazy today, but my IDLE was at a stead 1900 RPM!!!!
Old Nov 21, 2006 | 11:57 AM
AJ06's Avatar
******UPDATE*****
I Replaced the MAP sensor from my old engine, and now its running smoother...
It does do that irratic thing only when its real COLD.
Dont know why but it is....
BUT the check engine light still turns on...
After about 10 minutes of driving
Modified by AJ06 at 12:42 AM 11/22/2006
Modified by AJ06 at 12:43 AM 11/22/2006
Old Nov 21, 2006 | 01:40 PM
NormanBates's Avatar
when was the last time the spark plugs were changed?
Old Nov 21, 2006 | 09:41 PM
AJ06's Avatar
Default Re: (KillerAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerAccord &raquo;</TD></TR><TR><TD CLASS="quote">when was the last time the spark plugs were changed?</TD></TR></TABLE>
Not sure... Could have been a long while... before I had it in my posession... Im gonna call my father. He had it before me.
What makes u think its that?
Old Nov 22, 2006 | 03:19 AM
Default Re: (AJ06)
Fouled plugs can also cause what you describe...and for less than $20 you should definitely make that a part of your "tune up"....
