Codes 10 and 14 NEED HELP!!!
Old Oct 23, 2006 | 09:17 PM
z6_EF_obd1's Avatar
Default Codes 10 and 14 NEED HELP, ASAP!!!
Okay, So I swapped the IM on my z6 for the y8.
I got in the car to start it and I got codes 10 and 14(IAT and IAC)
So i switched the plugs, disconnected the battery for a few seconds, reconnected it and went to start it again... I got the same 2 codes!!!
Didn't make any sense, so i switched them again and took out the ECU fuse for 20 seconds. Went to start it and, you guessed it, same 2 codes!!!
Did this quite a few times to no avail.
Does anyone know what's going on?
FYI: running complete obd1 with p28. I'm using the same IAT I had on the z6 IM and i mounted it on my intake pipe, and a differrent IAC
Please someone help
Modified by z6_EF_obd1 at 10:28 PM 10/23/2006
Old Oct 23, 2006 | 10:14 PM
fmrprojects's Avatar
Default Re: Codes 10 and 14 NEED HELP, ASAP!!! (z6_EF_obd1)
did you plug them in the correct spots
Old Oct 24, 2006 | 09:16 AM
z6_EF_obd1's Avatar
Default Re: Codes 10 and 14 NEED HELP, ASAP!!! (fmrprojects)
IAC on the back of the IM and the IAT on the intake pipping, I did say i plug them in each others plugs, but i swapped them around a few times and that didn't work
Modified by z6_EF_obd1 at 2:00 PM 10/24/2006
Old Oct 24, 2006 | 01:10 PM
z6_EF_obd1's Avatar
BTW, I did put a b16a2 Throttle body with its gasket. Could this be the reason I'm getting those codes?
has anyone had this happen? do these sensors share a common ground?
Modified by z6_EF_obd1 at 5:31 PM 10/24/2006
Old Oct 24, 2006 | 07:00 PM
z6_EF_obd1's Avatar
Anyone?
Old Oct 25, 2006 | 07:49 PM
z6_EF_obd1's Avatar
bump
DeeEx Rex
14
May 5, 2011 05:36 PM
90efSI
Aug 2, 2006 12:15 PM
0618turbocivic
Jul 9, 2006 08:31 AM
downest
17
May 6, 2006 03:59 PM
Sho Pow
Sep 28, 2004 12:03 AM
