1992 H22A4 4WS ECU Wiring
Old Oct 23, 2006 | 08:13 PM
crj_lll's Avatar
Default 1992 H22A4 4WS ECU Wiring
In 2001 I had a H22A put in my 1992 Prelude SI 4WS. IT has ran as good as new with ZERO problems since I have the Swap done. About a month ago I began to install my JDM Climate Control. Part of the install calls for me to tape into the speed sensor line on the ECU. I picked up a standard P13 chart of the net from 3 different places for cross reference.
When I went to find the appropriate wire, I went to locate other wires for a reference point. Very few of the wires lined up with the charts I found in various locations on the net.
I am wondering if the guy who did my swap years ago, changed the pins around in some sort of way. Ever since the swap was done, the check engin light has been on and the AC has not worked along with the crusie control. But the car runs strong and with zero problems.
Before you ask, the work was done by a reputable shop. Some of you may have heard of them. Meccanic Shop, formally of Vahala, NY and now of North Salem, NY.
I did check with the dealership and the part numbers for a 1992/1993 P14 are different that a 1994/1995/1996 P14/ I have a P13 but checking the part numbers to the original ECU would let me know where the wires in the wire harnness are. The seperate part numbers makes me think their were 2 different pinouts for the P14.
Has anyone ever heard about this?
Modified by crj_lll at 9:45 AM 10/28/2006
Old Oct 28, 2006 | 12:46 AM
crj_lll's Avatar
Default Re: 1992 H22A4 4WS ECU Wiring (crj_lll)
Bump
Old Oct 28, 2006 | 01:00 AM
crj_lll's Avatar
Ok, I figured it out. I was counting the wrong direction. It 1 is above 2. I was counting the top row left to right and then the bottom row left to right. This solved the problem and everything lined up exactly. Just figured I would let everyone know the solution.
I found the count on the thread below.
https://honda-tech.com/zero...50329
ZENER
Apr 1, 2019 04:35 AM
Profounded
Aug 25, 2013 04:15 PM
Nooch
Jun 4, 2010 10:16 AM
builtsinglecam
Feb 28, 2009 10:58 PM
slamdlude
Dec 27, 2008 11:48 AM
