Is 168.6 power 120.4 torque high, low, or normal for my mods?
Old May 5, 2002 | 02:37 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Is 168.6 power 120.4 torque high, low, or normal for my mods?
See sig. for mods. I ran my first dyno today at E-town on a Dynojet. I ran three runs with the best of 168.6 120.4, and the other two were 166.3 119.9 & 166.1 120.4. I wanted the guy to bounce of the rev limiter, but he only did once. What do you guys think?
Old May 5, 2002 | 02:39 PM
SwiftTypeR's Avatar
New User
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (01PYTypeR#1140)
seems about right. i only dyno'd 170 whp with a intake and a jdm header.
Old May 5, 2002 | 02:40 PM
Rob :190:'s Avatar
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (SwiftTypeR)
i bet that oil cap is holding you back
sounds about right, I'm at 170 with I/H/E
Old May 5, 2002 | 02:42 PM
So I'm low, because you dyno'd higher with les mods.
Old May 5, 2002 | 02:46 PM
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (Brian Spilner 1035)
was that tuned or just slapping the I/H/E on?
Old May 5, 2002 | 02:47 PM
Rob :190:'s Avatar
no tuning, stock timing, PS and AC in place
cant really compare exact numbers, ITRs vary quite a bit. for I/H/E, i've seen numbers from 165-175, so your pretty much in the middle. nothing to be worried about.
[Modified by Brian Spilner 1035, 6:51 PM 5/5/2002]
Old May 5, 2002 | 02:53 PM
After the Dyno runs, I noticed I was a whole quart low on oil would that effect the outcome of my runs?
Old May 5, 2002 | 03:00 PM
FAST94GSR's Avatar
New User
if you lost a quart of oil just doing oil runs, you have a bad piston seal which means loss of compression. I personally feel you should be making more power with your mods but then again it ain't tuned. I would get a compression check.
Old May 5, 2002 | 03:02 PM
Racebrewer's Avatar
The oil level shuldn't affect your readings, but the weather might )temp,barometer and humidity). Were you numbers adjusted to the standards?
John
Old May 5, 2002 | 03:07 PM
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (FAST94GSR)
I haven't checked my oil for 2-3 weeks oil loss was not due to Dyno runs, but to not being able to stay out of VTEC.
Old May 5, 2002 | 03:09 PM
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (Racebrewer)
John
I'm not sure! How can I tell if they did so?
Old May 5, 2002 | 03:28 PM
Mike95lude's Avatar
It's low. I've seen numerous ITR's stock or very nearly stock dyno that much or more.
Old May 5, 2002 | 03:33 PM
tjtruong's Avatar
New User
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (Mike95lude)
my car dynoed at 175whp 122 torque on a clayton dyno..
with comptech drop in filter and apexi N1 catback....
tj
Old May 5, 2002 | 04:41 PM
STOLEN - ITR 98-0652's Avatar
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (tjtruong)
I got 174.6 / 121.x with AEM, Mugen (USDM), Mugen Twin Loop, and Unorthodox UDPs
YMMV
Old May 5, 2002 | 04:47 PM
tj
Are there normally differences in dyno results from a clayton & dynojet.
Old May 5, 2002 | 04:49 PM
Rob :190:'s Avatar
yeah a lot of dynos have different numbers.....
Old May 5, 2002 | 04:51 PM
Are Clayton dynos' Known to be a little higher?
Old May 5, 2002 | 05:04 PM
Unlimited's Avatar
New User
i dyno'd 172 / 121 with just the aem cai
Old May 5, 2002 | 05:24 PM
UNVMYR's Avatar
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (Unlimited)
I made 174.8/123.7 with jdm R and i/h/e on 17's in my si.
btw im at 17deg timming! Its funny cuz most of us in here are making a little more
power than that of the 168,yet the 14.3 q mile time is one of the best ive seen..
for a basicly stock set up!! I only put down a 15.2 at 92 (wtf).Keep in mind ive only made 2 passes.HtH
[Modified by UNVMYR, 2:38 AM 5/6/2002]
Old May 5, 2002 | 06:06 PM
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (UNVMYR)
That 14.3 was before the hood & the stickier street tires. How can you Dyno higher than me, but be close to a second slower? It can't be driver.
Old May 5, 2002 | 06:11 PM
SwiftTypeR's Avatar
New User
every car responds differently to mods. old saying but true. seems like my car loves dc sport headers, so im sticking with that.
Old May 5, 2002 | 06:16 PM
Old May 5, 2002 | 06:21 PM
Dr Pooface's Avatar
I made 168 120 stock on a Dynojet.
Isaac's Avatar
New User
Umm....how about trimming your profile? I know it's your own personal profile, but a seems a bit excessive.
Old May 5, 2002 | 06:23 PM
Rob :190:'s Avatar
Default Re: Is 168.6 power 120.4 torque high, low, or normal for my mods? (Waxing "The Carrot")
does 3 or 5 horsepower even matter? bragging rights arent that important to me...
