buddy club spec III
i heard that these are pretty decnt cams and upgrade over stock but on some web
sites it doesnt say anything about upgrading the valve spings and retainers. so for
the buddy club spec III is it requiered to have upgraded valve train or would my
stock jdm b16a be ok with just bolting on these cams?
I have these cams. I would suggest upgrading the valve train at least to type r spec. These are a bit higher lift than the type r cams. I upgraded to omni power springs and retainers.
yeah i just got the spec III+ and i also got some rocket motorsport valve springs, but im going to retain factory retainers since they last longer than titanium ones
and i garentee that your retainer wont last past 10kkk thats why people dont buy retainers taht often unless it is super necessary
just started car 2days ago but idles good ima get back to you guyz as soon as im done breakin it in and then ill take the rev limit up to 9500 should make some good power my friend has the same set-up but with 10.1 je pistons and 100shot of NX nitrous and he ran 11.2 on gforces so im goin all mota so im hoping for mid 12 wit 22" slicks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16FlatBack »</TD></TR><TR><TD CLASS="quote">just started car 2days ago but idles good ima get back to you guyz as soon as im done breakin it in and then ill take the rev limit up to 9500 should make some good power my friend has the same set-up but with 10.1 je pistons and 100shot of NX nitrous and he ran 11.2 on gforces so im goin all mota so im hoping for mid 12 wit 22" slicks</TD></TR></TABLE>
on what block and what mods ?
are these cams worth the money. i can get a set right now for 325 so im wondering if i should get it.. how much more power would i be looking at when all i have is what i listed and aem pulleys.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchan »</TD></TR><TR><TD CLASS="quote">are these cams worth the money. i can get a set right now for 325 so im wondering if i should get it.. how much more power would i be looking at when all i have is what i listed and aem pulleys.. thanks</TD></TR></TABLE>
yeah for that price pick them up becuase they make good amount of usable power through out the rpm range and have stock idle characteristics. and u can use them on stock or upgraded vavle train
if you guys are goin to use those cams and rev up pass 9k you might to upgrade bottomend to arp rod bolts on ur stock rods. if you are using stock rods with stock rod bolt you might damage your motor.
This thread is making my head hurt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j0hn-0h »</TD></TR><TR><TD CLASS="quote">how would these do in an lsvtec?</TD></TR></TABLE>
https://honda-tech.com/zerosearch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchan »</TD></TR><TR><TD CLASS="quote">cool thanks? what kind of power should i expect from em? </TD></TR></TABLE>
Put it on a dyno and find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">and i garentee that your retainer wont last past 10kkk thats why people dont buy retainers taht often unless it is super necessary</TD></TR></TABLE>
Guaruntee huh? Hope you wouldnt put money on it, because id be taking it right now. Plenty of people have gone over 10k on Ti ret.
And just a thought to leave you all with, is the only reason to upgrade your valvetrain improved reliability?
