help required to change tranny oil
ummm...ok this is giong to sounds totally useless of me...
but where do i begin, in regards to changing the transmission oil?!...obviously i can buy the tranny oil from Honda (i'm fine with that thankfully hehe)...but i have no idea what to drain; ie what plugs/bolts to undo
is it plausible to advise on this thread? (or is it too much info to write up)...any online guides?...i dont have a helms manual
Ok if you look at your tranny the drain plug is just a square that fits into a 3/8 ratchet w/ no socket attached. The filler is right above it to the left you need a long funnel or a rubber hose fill it up and replace the washers.
classciv
Apr 19, 2006 04:49 AM
