how thick wheel spacer is too thick
Old Oct 23, 2006 | 06:55 PM
kenh's Avatar
Default how thick wheel spacer is too thick
My kid just bought new 18" wheels for his 98 civic. The hub of the front wheel hits the caliper mount (the bar that runs from the top to the bottom. I used some washers to get a thickness for a wheel spacer and came up with 6.2 MM or about 1/4 inch. This gives me just a hairs breath between the wheel and the caliper mount. How much can be ground off the bar on the caliper mount and how thick is too thick for a wheel spacer. If I had my way, I wouldn't use any spacer at all.
Thanks in advance!!
Ken
Old Oct 23, 2006 | 07:49 PM
dvp's Avatar
dvp
Default Re: how thick wheel spacer is too thick (kenh)
He bought a rim not made for the car.
I wouldn't grind any part of the bakes.
Maybe a small portion of the backside of the wheel if it wont weaken it. Or use a spacer. 6mm isn't too bad.
Old Oct 23, 2006 | 08:08 PM
kenh's Avatar
Default Re: how thick wheel spacer is too thick (dvp)
I can't remember for sure, where he mail ordered the rims from, maybe Wheels Next, but he was assured that they would fit "perfectly". I guess we need to define "perfect".
Ken
Old Oct 23, 2006 | 10:12 PM
vtecsi00's Avatar
you can gring that part of the brakes to a degree without harming anything...BUT
if you decide to do that make sure you have brand new pads on when you do......
but if it were me i would return the wheel's and get the right one's that fit your car correctly
Old Oct 24, 2006 | 05:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: how thick wheel spacer is too thick (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">but if it were me i would return the wheel's and get the right one's that fit your car correctly</TD></TR></TABLE>
Otherwise, you would be better off using a full spacer plate (see below) than individual washers. And whatever you use, make sure you still have at least six full turns on the lug nuts (seven is even better).
Old Oct 25, 2006 | 11:07 AM
ASpecProducts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenh &raquo;</TD></TR><TR><TD CLASS="quote">My kid just bought new 18" wheels for his 98 civic. The hub of the front wheel hits the caliper mount (the bar that runs from the top to the bottom. I used some washers to get a thickness for a wheel spacer and came up with 6.2 MM or about 1/4 inch. This gives me just a hairs breath between the wheel and the caliper mount. How much can be ground off the bar on the caliper mount and how thick is too thick for a wheel spacer. If I had my way, I wouldn't use any spacer at all.
Thanks in advance!!
Ken</TD></TR></TABLE>
you can use spacers, but make sure you have at lease 7 FULL turns with you put your lugnuts on torque them down to 85lbs~95lbs you should be save. spacers will bring some wobble to the steering wheel, also bring some feathering to the tires. so just keep rotating tires you should be fine.
Fitz Williams
Jan 10, 2016 04:52 AM
Greatness
Jan 3, 2010 09:33 AM
hardvtec90
Oct 28, 2008 02:59 PM
esponet
Jan 8, 2004 04:47 PM
civbeater90
Aug 5, 2002 11:26 PM
