Suspension & Brakes Theory, alignment, spring rates....
Bump stop hitting the spring insulator, what to do? Need pix of GC spring insulators
Old Oct 23, 2006 | 04:48 PM
aleks77's Avatar
Default Bump stop hitting the spring insulator, what to do? Need pix of GC spring insulators
hey guys i got my koni yellows and ground controls, the only part missing is the ground control spring insulator, which i dunno what it looks like, my spring insulators have like a 12mm inner hole, i think what i have to do is make the hole in the spring insulator as big as the koni shock body? so that the bumpstop can go thru the spring insulator and actually into the top hat hittin that bushing, right now i have only like 1" of suspension travel in the back, and like 0.2" in the front, and the car rides like ****, so im gonna raise it until i figure out how to fix it
the car is a 91 accord, and they dont make extended top hats for it Might have to make my own.
Anyone have pix of the ground control spring insulator, i think its black? thanks a lot
Old Oct 23, 2006 | 04:56 PM
Tyson's Avatar
Default Re: Bump stop hitting the spring insulator, what to do? Need pix of GC spring insulators (aleks77)
what are you referring to as the OEM "spring insulator"?
Old Oct 23, 2006 | 11:49 PM
aleks77's Avatar
Default Re: Bump stop hitting the spring insulator, what to do? Need pix of GC spring insulators (Tyson)
there is NO oem spring insulator, i have a spring insulator from another set of sleeve-overs, its the part that goes into the top of the spring and keeps it from moving around, aftermarket springs are a lot less diameter then stock so they need these, in the pic below its the red part....
Old Oct 24, 2006 | 12:00 AM
importdude2000's Avatar
man
GC chrages 73 bucks shiped new
i just orderd a set
then sold my setup
ground control isolators are like stock but urthrne
and its there a BIG HOLE LIKE STOCK BUSHINGS
Old Oct 24, 2006 | 12:24 PM
nonsense's Avatar
I think you mean the piece that is like #10 in the pic above right? You remove the stock one and put on the GC one. I'd just call GC and ask if they can send a set to you. The ones that GC provides are poly urethane.
or are you talking about the metal collars that the shaft goes through like this?
if so, yeah you need 12mm ones. You can probably get them from koni-na.com
Old Oct 24, 2006 | 04:09 PM
aleks77's Avatar
in the pic off of ebay sleeve-overs above, its the red part, i guess its #10, im not talking about the metal cylinder thing. Is it a bad idea to run the setup without the spring insulators?
Old Oct 24, 2006 | 04:17 PM
Tyson's Avatar
Default Re: (aleks77)
alright. i get it now.
youre comparing these cheap generic ebay kits to ground controls.
GC for hondas dont have those machined, aluminum and anodized "spring isolators". ive never seen them used. maybe theyre for macpherson strut cars. dunno. but thats why we are confused.
GC sometimes includes poly urethane spring cushions. its not much wider nor have a smaller ID than the spring and will fit the ID of the spring itself. its just to prevent metal to metal contact from the top of the spring and the top hat mount.
actually, some GC springs will fit in the STOCK rubber spring cushions. #10 in the picture. you should just see if that works. if you dont have em, get em. or get the poly ones from GC.
Old Oct 24, 2006 | 11:09 PM
aleks77's Avatar
GC will NOT sell me the poly ones, they say they dont even have enough for the kits they sell......I always thought that if i dont put those aftermarket ones on the spring will just wobble around and touch the shock body too? I have koni yellows with ground controls made for koni yellows. Im gonna see what i can do, i have the old "spring cushions" from my shitty sleeve-overs, im prolly gonna just make the middle wide enough for the shock body to go thru, for now i raised my car cause i only had about an inch or so of suspension travel and the ride was just horrible, thanks for all the help guys, hopefully i can do without the GC Spring cushions
Old Oct 24, 2006 | 11:14 PM
Tyson's Avatar
try sticking them in OEM ones. get em from the junkyard or whatever if you need to.
Old Oct 24, 2006 | 11:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">GC will NOT sell me the poly ones, they say they dont even have enough for the kits they sell......I always thought that if i dont put those aftermarket ones on the spring will just wobble around and touch the shock body too? I have koni yellows with ground controls made for koni yellows. Im gonna see what i can do, i have the old "spring cushions" from my shitty sleeve-overs, im prolly gonna just make the middle wide enough for the shock body to go thru, for now i raised my car cause i only had about an inch or so of suspension travel and the ride was just horrible, thanks for all the help guys, hopefully i can do without the GC Spring cushions</TD></TR></TABLE>
i just bought a set a week ago
man
73 shiped
give me 68 shiped and its urs
drove like 10 miles on setup and it sucked so i put in full coils
ill get pics tomaro
Old Oct 25, 2006 | 07:06 AM
nonsense's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">
man
73 shiped
ill get pics tomaro </TD></TR></TABLE>
a set of what for $73? The poly mounts?
Old Oct 25, 2006 | 12:03 PM
Default Re: (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
a set of what for $73? The poly mounts? </TD></TR></TABLE>
upper urthene spring inserts that go on top of spring
Old Oct 25, 2006 | 03:42 PM
aleks77's Avatar
hey ya ill take them man, shoot me some pix, if u got msn: aleks56@hotmail.com and also need the inner hole diamter, it has to clear my koni shock......thanks man!!
Old Oct 25, 2006 | 07:19 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">hey ya ill take them man, shoot me some pix, if u got msn: aleks56@hotmail.com and also need the inner hole diamter, it has to clear my koni shock......thanks man!!</TD></TR></TABLE>
You have the Koni-specific GCs right? This pic shows the koni-specific setup with the poly inserts. I think the ID should be large enough for the whole shock to fit into it.
Old Oct 25, 2006 | 11:23 PM
aleks77's Avatar
Sold to me thanks man!
Bustin_Hatch305
Suspension & Brakes
22
Sep 5, 2012 03:28 AM
uses0ap
Jul 4, 2009 07:44 AM
GSRfromdaBAY
Mar 14, 2008 12:57 PM
mofuckinarnell
Suspension & Brakes
Jun 30, 2005 12:41 PM
USCdrifter
Apr 27, 2002 01:18 AM
