Alternator charging issue...
Old Oct 23, 2006 | 02:24 PM
JDM_Risa's Avatar
Default Alternator charging issue...
anyone care to guide to me to the right place upon getting a higher ampage alternator...
i don't have a system of any sort just your basic cd player and a jdm front end with HID... i been dealing with this issue for the pass 4 months when i decelerate with my foot firmly on the brake with all my accessory on at night my car would shut off immediately towards lower rpm...so i then went to Sears near by local Auto Center they performed a battery test inspection...battery results were 410 CCA, Starter Test cranking volts= 10.65 Charing Test load volts=13.86 no load volts=14.00 so i then was frustrated and went to local Acura of Steven Creek Blvd ... factory oem acura battery CCA showed 500 CCA now my car runs really good voltage gets low but doesn't stall out i know this due to my Apexi pen timer with voltage reading...first 3 days i was able to drive with my headlights on and what not....i stalled out again for the first again after a long day of driving when i went to turn the headlights on...i think my only alternative now is to get a custom built alternator...i heard ohio generator and powermaster sell them...any other thoughts upon this topic
thanks in advance
Old Oct 23, 2006 | 03:39 PM
NJIN BUILDR's Avatar
Default Re: Alternator charging issue... (JDM_Risa)
Sounds like the alternator is spinning to slow at idle.Do you have the original pulleys on it ?The stock alternator should be fine.
Old Oct 23, 2006 | 04:42 PM
JDM_Risa's Avatar
Default Re: Alternator charging issue... (NJIN BUILDR)
forgot to mention i have an ATI fluiddampner....and the alternator is completely stock i even replaced it thinking it was bad...
Old Oct 23, 2006 | 04:54 PM
Is the pulley on the ATI you have smaller than the stock one? If it is than that is more than likely your problem.The alternator needs a minimum speed to start charging.
9thgenidiot
Aug 28, 2015 10:22 AM
c1v1c98
Nov 27, 2005 01:47 PM
DayOh257
Dec 15, 2004 04:39 PM
honcrx91si
May 16, 2004 01:46 PM
DesiDez
Jan 31, 2004 05:17 PM
