Honda S2000 Honda S2000
Aftermarket steering wheel.......will the passenger air bag still work?
Old Oct 23, 2006 | 01:27 PM
p71sohc's Avatar
Default Aftermarket steering wheel.......will the passenger air bag still work?
I want to use the sparco 383 steering wheel but the only way I will swap out the wheels is if the passenger air bag will still deploy in an accident. Does anyone know If the swap will work? Thanks! Joe.
Old Oct 23, 2006 | 02:53 PM
WowOzYouRock's Avatar
Default Re: Aftermarket steering wheel.......will the passenger air bag still work? (p71sohc)
yes, it would still work ..
Old Oct 23, 2006 | 03:52 PM
p71sohc's Avatar
Default Re: Aftermarket steering wheel.......will the passenger air bag still work? (FR-MOB: Jerk)
that's what I was looking for, thanks!
Old Oct 23, 2006 | 03:59 PM
only manually though
Old Oct 23, 2006 | 04:02 PM
^^^ hahaha jk yes it would still work
Old Oct 24, 2006 | 01:34 PM
s2kdre's Avatar
nope, once u disconnect the driver airbag the other wont work.
Old Oct 24, 2006 | 02:35 PM
Default Re: Aftermarket steering wheel.......will the passenger air bag still work? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">nope, once u disconnect the driver airbag the other wont work.</TD></TR></TABLE>
ROFL are you sure about that? ... funny cuz i experienced it ... i have splash short hub/signal quick release/ and spoon steering wheel ... and when i got into an accident, the passenger airbag still deploy
Old Oct 26, 2006 | 12:35 PM
evil vapor's Avatar
you'll need to run a 2ohm resistor to fool the SRS system that the airbag is still connected.
Old Oct 26, 2006 | 12:52 PM
Default Re: Aftermarket steering wheel.......will the passenger air bag still work? (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">you'll need to run a 2ohm resistor to fool the SRS system that the airbag is still connected. </TD></TR></TABLE>
only to get rid of the SRS light ...
Old Oct 26, 2006 | 02:52 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">
only to get rid of the SRS light ... </TD></TR></TABLE>
tested it out recently?
Old Oct 26, 2006 | 04:22 PM
tested it out recently? </TD></TR></TABLE>
yes ... splash short hub comes with a wire and resistor/fuse to get rid of the SRS light
Old Oct 27, 2006 | 10:32 AM
evil vapor's Avatar
yes ... splash short hub comes with a wire and resistor/fuse to get rid of the SRS light </TD></TR></TABLE>
I know about the srs light, but your statement below can be read that the resistor will only get rid of the srs light and not enable the full function of the passenger airbag. That's why I asked you if you tested out the deployment of the passenger airbag when running an aftermarket steering wheel.
Old Oct 27, 2006 | 01:16 PM
SilverDc2's Avatar
got some quick instructions vapor?
Old Oct 27, 2006 | 09:13 PM
howl's Avatar
Not sure about the s2000's, but with my DC5 the Acura dealer told me that all airbags are disabled if the SRS lights come on. When i asked about the resistor trick, the tech told me that in theory it should work, but that he wasn't 100%... Personally i think the resistor trick would work because you're completing the circuit and fooling the SRS system into thinking everything is cool. So it should still fire the other airbags correctly..
Old Oct 29, 2006 | 01:41 AM
AWD: Jeff's Avatar
Default Re: Aftermarket steering wheel.......will the passenger air bag still work? (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">got some quick instructions vapor?</TD></TR></TABLE>
http://www.s2ki.com/forums/ind...90875
Old Oct 29, 2006 | 11:41 AM
nautica_t's Avatar
interesting.
Old Oct 30, 2006 | 12:01 PM
evil vapor's Avatar
Default Re: (howl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howl &raquo;</TD></TR><TR><TD CLASS="quote">Not sure about the s2000's, but with my DC5 the Acura dealer told me that all airbags are disabled if the SRS lights come on. When i asked about the resistor trick, the tech told me that in theory it should work, but that he wasn't 100%... Personally i think the resistor trick would work because you're completing the circuit and fooling the SRS system into thinking everything is cool. So it should still fire the other airbags correctly..</TD></TR></TABLE>
that's how I understand the system as well but I don't think anyone can verify that. I would only run airbags on a 3pt seat belt system/street driven car.
Old Oct 30, 2006 | 02:18 PM
Default Re: (evil vapor)
even if you dont put fuse/resistor the passenger side airbag would still work... the line is parallel, NOT series... the resistor trick only to get rid of the SRS light to complete the circuit ...
ask me how i know ...
Old Oct 30, 2006 | 04:13 PM
Nishant's Avatar
Default Re: (FR-MOB: Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">even if you dont put fuse/resistor the passenger side airbag would still work... the line is parallel, NOT series... the resistor trick only to get rid of the SRS light to complete the circuit ...
ask me how i know ... </TD></TR></TABLE>
cause your crashed the car like a noob trying to drift
Old Oct 30, 2006 | 11:13 PM
Default Re: (Mr. Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
cause your crashed the car like a noob trying to drift </TD></TR></TABLE>
STFU...
this was back in year 2000 when my airbag deploy on my 96 civic just by hitting a huge pothole... i had an aftermarket steering wheel ... i took out the "wire rotor" and didnt do the resistor trick and my passenger airbag still deploy...
now this year on my s2000, i had spoon steering wheel and did the resistor trick ... and my passenger airbag still deploy ...
you get the idea
Bango_Vang01
Apr 13, 2010 10:36 AM
jhonda239
14
Jul 12, 2008 07:03 AM
cinaibur
Honda Civic (2001 - 2005)
16
Nov 10, 2006 10:41 AM
2000 Integra R #760
Feb 6, 2005 12:19 PM
Myogi_Nightkid
Aug 3, 2004 11:10 AM
