NEED SOME HELP AND ADVICE!!! JDM B16a question???
i have a 99-00 civic si SHELL and was curious if i bought the jdm 95 b16a instead of the 99-00 civic si b16a2 swap .... what would i exactly need to make it work in my em`1 civic si shell .....
please be detailed and eleborate .... thanks honda-tech
assuming your not buying a full swap:
1. conversion harness to obd 1
2. p30,p28,p72 ecu (p30 i would suggest there are a couple for sale right now i just looked)
3. si linkage
4. si axles
5. si intermediate shaft
6. mounts (si or whatever u want)
3. si linkage
4. si axles
i aprecieate all the info .... if theres anything anyone missed please leave comments ... thanks
Well instead of buying a conversion harness that probably wont let you pass inspection. You can get the motor and change the distributor, also the crank fluctuation sensor and i believe it converts it to an OBD2. Also an oil pump, but double check this as i im not 100% sure. Im sure someone here can correct what ive said...
b16_swap
Apr 29, 2008 11:42 AM
singleslammer
Jul 21, 2006 05:43 AM
