B18B/B18A alternator question
Old May 5, 2002 | 12:47 PM
B_CRUZ!'s Avatar
Default B18B/B18A alternator question
Will a 1998 B18B ALTERNATOR bolt up to a B18A?
My friend is currently building a 98 hatch but he is having trouble with the alternator. he has a B18A from his old integra and a DRAG3 kit on it. he is using the 98 Civic harness and the alternator plug has 4 wires. the B18A alt has 3 wires with a totally different looking plug.
TIA
Old May 5, 2002 | 04:03 PM
B_CRUZ!'s Avatar
Default Re: B18B/B18A alternator question (B_Cruz)
ttt
Old May 5, 2002 | 06:18 PM
B_CRUZ!'s Avatar
Somebody? anybody? everybody screammmm!
Old May 6, 2002 | 10:05 AM
B_CRUZ!'s Avatar
ttt
Old May 6, 2002 | 01:48 PM
OneSunkCivic's Avatar
I'm pretty sure there are two grounds and you can get rid of one I forget which one I had the same problem when I swapped my b18b into my 96 civic ex. hope this gives ya some more info to help ya out
Old May 6, 2002 | 04:40 PM
erniecars's Avatar
Default Re: B18B/B18A alternator question (OneSunkCivic)
i think a b18a from a 92-93 integra (OBD-1)will have the same alternator as a b18b
[Modified by erniecars, 7:41 PM 5/7/2002]
Old May 6, 2002 | 07:02 PM
iww's Avatar
iww
Default Re: B18B/B18A alternator question (erniecars)
I dont think it will work. They are the same size and have the same bolt pattern but the connectors are different.
Old May 7, 2002 | 07:27 AM
B_CRUZ!'s Avatar
car: 1998 DX hatch
motor: B18A
engine harness(motor to shock tower): 1998 Civic harness
so my friend can bolt up a OBD2 B18B alternater to the motor? i told him to use the 98 B18B alternater so the wiring plugs would match up. then i told him to use a OBD2-OBD1 jumper harness so he can use a OBD1 LS ecu. am I giving the right advice?
Old May 7, 2002 | 07:29 AM
WAFFLES's Avatar
ive got one from a b18a on my b16 it fits no problems.
Old May 10, 2002 | 10:22 PM
EF_LSVtec's Avatar
Default Re: B18B/B18A alternator question (WAFFLES)
The alternator from my 97 B18b has a square plug so I traded them for a 91 LS alternator and it has a round plug and it worked...
AdrenalineAngel
Engine Management and Tuning
Oct 17, 2012 11:43 PM
B*Goods*EJ2
Jan 9, 2009 07:47 AM
asocallocal
Mar 7, 2008 09:23 PM
boosted96coupe
Mar 10, 2007 11:21 AM
95GSRTT
Oct 4, 2004 03:45 PM
