Turbo v.s. Supercharged
Old Oct 23, 2006 | 12:15 PM
gustavito1986's Avatar
Default Turbo v.s. Supercharged
im still new to this whole scene but from what i know, turboing a car is a lot of up keep/ matience. wouldnt be to good if my car was a daily driver. so a supercharger how much more different is it? would it put more wear and tear on the car if i used it was a daily driver? whats the ups/downs of this. any suggestions would be appreciated. oh i got an 02 accord fyi.
Old Oct 23, 2006 | 12:19 PM
msedacca's Avatar
Default Re: Turbo v.s. Supercharged (gustavito1986)
its obviously easier to break something if you've got a turbo, its forcing higher compressed air in, whereas a supercharger doesn't at such a high rate (unless you are comparing a 9psi supercharger and a low boost turbo). If you've got the option to supercharge, and you want to daily drive your car with low upkeep, definetly look into that. If you've got a v6, then look at Comptech supercharger packages.
Old Oct 23, 2006 | 12:24 PM
j-spec_cc2's Avatar
Default Re: Turbo v.s. Supercharged (msedacca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msedacca &raquo;</TD></TR><TR><TD CLASS="quote">its obviously easier to break something if you've got a turbo, its forcing higher compressed air in, whereas a supercharger doesn't at such a high rate (unless you are comparing a 9psi supercharger and a low boost turbo). If you've got the option to supercharge, and you want to daily drive your car with low upkeep, definetly look into that. If you've got a v6, then look at Comptech supercharger packages. </TD></TR></TABLE>
and the difference between 9psi S/C and 9psi Turbo is.......
Old Oct 23, 2006 | 02:47 PM
philadd's Avatar
Default Re: Turbo v.s. Supercharged (j-spec_cc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-spec_cc2 &raquo;</TD></TR><TR><TD CLASS="quote">and the difference between 9psi S/C and 9psi Turbo is....... </TD></TR></TABLE>
Power delivery...
Not to mention "9 psi" is relative to the turbo or supercharger. 9 psi on a T25 does not equal 9 psi on a T88.
But let's make this a bit more simple, shall we? If you have a 4-cyl, than your only choices are really turbos. If you have a V6, you're pretty much limited to the Comptech Supercharger. There are some custom-built options, but I'll leave that out for now.
Old Oct 23, 2006 | 03:01 PM
TheMuffinMan's Avatar
He knows where you live!
Yep there is no supercharger made for the f22b1/2's. Some person was doing custom fab of one, dunno if it was ever finished
Old Oct 23, 2006 | 03:41 PM
BlUAc's Avatar
Default Re: (TheMuffinMan)
for the f22b1 you could use a centrifical blower rather than the positive displacement one for a custom setup but im more of a turbo kind of guy. no drag on the motor but there is lag pretty much they both have their ups and downs its more of a personal preference then any thing
GrlRcr4
12
Mar 19, 2007 09:44 PM
husller4life
Nov 21, 2005 12:59 PM
cstyleaccord
Mar 30, 2005 06:25 PM
xsists
Apr 14, 2004 08:28 PM
jstyle
Aug 29, 2003 12:03 PM
