resistor box
Old Oct 23, 2006 | 10:55 AM
175Shot4Door's Avatar
Default resistor box
if i have a 88 civic DPFI and im making it a obd1 mini me do i need a do i need the resistor box??? and if i turbo it using DSM 450s do i need the DSM resistor box or can i use one out of like a 92 civic ?
Old Oct 23, 2006 | 10:57 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: resistor box (175Shot4Door)
If you are doing obd1 no you do not need it.
You will need all the things for wiring mpfi and obd1 though, rywire and boomslang should offer harnesses for just such a task.
Old Oct 23, 2006 | 11:01 AM
downest's Avatar
Default Re: resistor box (Capt. Blonde Beard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">If you are doing obd1 no you do not need it.
You will need all the things for wiring mpfi and obd1 though, rywire and boomslang should offer harnesses for just such a task.</TD></TR></TABLE>
It doesn't matter what OBD you're running, it matters what injectors you run. OBD0 injectors need it, even if your car is OBD1. The DSM 450cc injectors also need it (the stock one works IIRC).
There's always a lot of argument over this for some reason...
Old Oct 23, 2006 | 01:02 PM
NikoZai's Avatar
Default Re: resistor box (downest)
You must use the injector resistor box with DSM 450's.
GL gona be a fun car.
surkitroller
Dec 29, 2009 12:58 PM
Hondamonster
Jul 29, 2007 08:42 PM
VTEC1n2nd
12
Jun 27, 2007 05:46 PM
ef9ontime
May 28, 2006 01:23 PM
mr. Grind
Aug 13, 2004 04:08 PM
